Question about Bose Wave Radio
Can not get the unit to turn on...we have power and clock display is working
    Problem Solver:
  • 15 Answers
The remote is not reading your request because a new battery is needed in the remote.
Posted on Nov 08, 2010
  • Anonymous Nov 08, 2010
    Make sure that your mute button is off, then try to turn on.
My whirlpool oven display lights will not come on evn though teh unit has power and teh surface heaters work
What will cause that is a part on the clock that powers the display to illuminate has gone out yet the part of the clock (also called the electronic oven control) that send power to the heat elements is still working.It may work like that for years as long as you done mind the clock not displaying, OR to get it to display the clock/eoc would need to be replaced .
Gene
Aug 06, 2011 | Whirlpool Ovens
HOW DO YOU SET THE CLOCK ON THE DEP-P4000UB
STEP ONE (PRELIMINARY): With the key in the ignition, turn the ignition to ACC (accessory power) or this can be done while the vehicle is running. If unit remains off, proceed to the next step, but if unit is already powered on, power it down by pressing [Source] until it goes off. (Then, proceed to the next step.)
STEP TWO: Press MULT-CONTROL & hold until CLOCK SET displays. (To cancel at any time, press [Band/ESC]. Press [Back] to return to previous display.)
STEP THREE: Press MULTI-CONTROL to select the desired segment of the clock display to set. Each time MULTI-CONTROL is pressed, it selects (blinks) one clock display segment: Hour - Minute.
STEP FOUR: Turn (or push) MULTI-CONTROL (up/down) to change the clock display segment setting.
Apr 10, 2011 | Pioneer Car Audio & Video
How to set clock clok tcr368
Setting the CLOK TCR368 is done by having the unit:
Turned OFF - The power button is located at the top left face of the unit.
Press and hold the CLOCK/DISPLAY/PLAY/PAUSE button for at least 4 seconds. (It is located to the right of the power button at the upper left corner of the unit.) Do not let go of the button.
While holding down the CLOCK/DISPLAY/PLAY/PAUSE button, press the HOUR and MINUTE buttons to the correct time.
Release thethe CLOCK/DISPLAY/PLAY/PAUSE button.
The backup battery is to keep the clok circuit running in case of a power failure and can't be used to power the radio.
With the unit OFF, press and hold the FUNCTION button (located between the ipod slot and the snooze button) for at least 2 seconds. The display will flash either 12 hour or 24 hour depending what mode it is in.
Release the FUNCTION button and press it once to change the mode.
Press again to cycle between the 12 hour and 24 hour mode.
When the display indicates the mode you prefer, simply wait 2 seconds for the clock to go into that mode without pressing anything.
Sep 20, 2009 | Digital Products International Clok Smooth...
Insignia clock radio goes to 12:00 after turning off power
I found this solution by reading some reviews. A reviewer said it was caused by a weak backup battery that powers the display. He said to change the lithium backup battery of the main unit with the backup battery in the remote. I tried it and now it works. I can turn the unit on and off and it doesn't reset my memory. But this hasn't solved my problem with setting the alarm.
Nov 23, 2008 | Insignia Digital Clock Radio with Apple...
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Have Pioneer DEH 1900MP CD receiver. Do not know how to set time. Have no amnual. Also information on the remote control
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
from this unit.
turns off.
settings.
particular setting.
Setting the clock
clock display:
Hour—Minute
on or off.
on or off.
Operating this unit
12 En
Aug 05, 2008 | Car Audio & Video
Clock display board
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Apr 11, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
Bose Wave Radio Logo
130 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
