Question about Neff U1721 Double circotherm Electric Oven
The fan assisted oven does not heat up - Neff U1721 Double circotherm Electric Oven
  • 1,711 Answers
You fan heating element need to be replaced. Here below is some videos that will help you find and replace the element
http://www.youtube.com/watch?v=j3TPHgf1MRg&feature=channel
http://www.youtube.com/watch?v=wNdW2s7eEGg&feature=channel
Posted on Nov 07, 2010
  • 197 Answers
SOURCE: Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Posted on Oct 09, 2009
Testimonial: "Thanks, that helps. Will it be easy to fix? can I do it myself? "
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
hi-fi
  • 25 Answers
SOURCE: neff fan assisted oven
sonuds like the heater is not functioning,check thermal fuse or you call repairman to asist you for speedy repair of your oven.
hope it may help,
regards
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: Hi, i have a NEFF
Needs new element
Posted on Sep 23, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
I have chef EGC651S oven with separate grill. On fan assist oven only heats up to a certaain temp and doesnt get any hotter what could be the reason for this
Probably thermostat problem, although some chance you have one side of a 220vac breaker not working. In otherwords oven heating element is "getting" half of the required power. Call electrician!
Mar 08, 2015 | Ovens
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
Smeg fan assisted oven not heating up , top oven works fine but main bottom oven doesnt heat up at all but fan working fine many thanks
So long as fan is working o/k, then all you need to do is replace the oven element at rear of oven
Please rate my solution.
Thanks
Nov 10, 2009 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Neff U1721 Double circotherm Electric Oven Logo
772 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
