Question about Poulan Garden
How to adjust carburetor on weed eater xt 20 - Poulan Garden
    President:
  • Poulan Master
  • 1,545 Answers
Here is a basic tutorial for 2 stroke diaghragm carburetors.
http://www.zamacarb.com/tipspage.html
Posted on Nov 07, 2010
Is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Carburetor adjustment procedure
low and hi speed mixture screws
one adjusts for proper idle
one adjusts for proper high rpm operation
turn them in or out to get the best throttle response and proper wide open throttle rpm's
Aug 26, 2014 | Weed Eater Fl1500 Le Leaf Blowers
Why does my fl-20 need the choke to run?
the carburetor is clogged. it needs to be cleaned. if it will run on choke that means that it is starving for fuel but if it runs at all it is an easy fix. just take the carburetor apart and clean with carburetor cleaner good and it will run like new. good luck
Aug 11, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
What is the purpose of having two different size fuel lines in the fuel tank on a weed eater trimmer ?
Weed eaters have a diaphram operated carburetor instead of the float operated ones on a lawnmower. The bigger one is the fuel to the carburetor and the little one is the return to the tank from the carburetor.
Jul 27, 2011 | Garden
Weed eater xt 260 choke lever is broken...can it be replaced easily
It is not listed as a replacement part on the carburetor. You would have to remove the choke plate, and the choke shaft from the carburetor. These parts are press-fitted into the carb housing and the choke lever is also press fitted onto the choke plate shaft.
May 25, 2011 | Garden
How to adjust the carby on a poulan xt 20 type 1 weed eater
If your unit is fitted with a Walbro diaphragm carburetor, use this:
http://tech.flygsw.org/walbro_tuneup.htm
If your unit is fitted with a Zama carburetor, use this:
Dec 16, 2010 | Poulan Garden
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Garden Logo
600 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
