Question about D-Link Computers & Internet
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is connected. Please ask why? I just reinstalled Windows XP
  • D-Link Master
  • 7,733 Answers
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Posted on Nov 07, 2010
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
I have a D-Link DSBroadBand G ADSL2+router. I cannot access the internet with the ether cable plugged in. I can access the internet via wireless and the ethernet cable with a laptop. I am able to access...
I suspect that your ethernet adapter has been made 'not enabled', but can't explain how to check it since I don't know which version of windows you're running. If you can get to the Device Driver panel, you can change it there...
May 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
My D link ADSL2 plus router work fine thru ethernet cable but has no wireless signal
while connected with a wire surf using internet explorer into the routers console its either at 192.168.0.1 or 192.168.1.1 (most of the time anyway) , Enter the username and pass to get in, often both are admin or admin and blank. check the wireless tab settings in there to see if its enabled and configured.
Aug 27, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Need drivers for DSL-G624t wireless router
If you're connecting to the router by ethernet cable or wirelessly, you dont need drivers unless you mean the drivers for the ethernet adapter and/or wireless adpater in your PC.
If this is what you're after, your PC's manufacturer's website is the best place to look if you dont have them on CD/DVD.
If you're connecting to the router by USB port, then the D-Link webiste should have the drivers for downloading.
Sep 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
I need to connect my router to a Motorola AT&
The connection should be, from the modem connect the ethernet cord to the INTERNET/WAN port of the router. And your PC to port 1 of the router as well. You can then run the setup CD That came with your router.
Jun 24, 2009 | Computers & Internet
Trying ti install my dsl-2640b wireless g adsl2+modem router
If you have plugged the ethernet cable directly into the motherboard, make sure the onboard lan is enabled in the bios, if you have plugged into a pci nic adapter you will have to install a driver for it, winxp should have the driver for your adapter other than that I cannot help any further.
best of luck
Ray Winter
Dec 30, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Adsl2+
don't go for the cd you configure your self abd it think that your dsl not get the perfect dsl link
Jul 10, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Belkin router F5D7230-4
To be honest, I have installed several routers of my own and it runs better without the installation CD. Those CD's are controlling and make your life harder. All you need to do is turn off your computer. Then turn off your cable/DSL modem and unplug the power. Take the router, position it where you want, and plug in an ethernet cable going from the Modem to the back of the router in a slot labeled Internet. Then power on the modem and let it run for 1 min. Then power on the router, let run for 1 min. Take a second ethernet cable and plug it into your router labeled "1" and into the computer. Turn on the computer and check to see if you have internet. If you do, then you are good to go.
If you need additional help, contact me with a direct message.
Apr 11, 2008 | Belkin (F5D7230-4) Router (587009)
LinksysWRT54GS V7 Wireless Router
So if I understand you, you have an ethernet cable running from your DSL modem to the Internet port on the back of the Linksys router and then an ethernet cable connecting one of your computers to one of the numbered ports on the router. Is that correct?
If the above is correct, using the computer that is hooked to the router via the cable, open Internet Explorer and type the following in the Address Bar:
http://192.168.1.1
The Username should be left blank and the default password is "admin" with no quotes.
See what happens when you try this and let me know. This may take a few steps to get going.
Dec 30, 2007 | Linksys Wireless-G WRT54G Router...
Computers & Internet Logo
94 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
