Question about Kenmore Ovens
I was doing a self-cleaning of my Kenmore oven. I tried to open the oven by moving the lever to the left, and it would not budge. Then I started getting a warning beeping and an F2 message. How can I get the oven back open? Thanks
  • Kenmore Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Nov 07, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
I cannot open the oven door to my GE oven. I had to move a lever from left to right. After cleaning, I moved it back to the position it should be in (while not cleaning) but the oven door is still...
Most of these self-cleaning stoves have to cool down before the door can be opened. This is a safety feature. Has the oven completely cooled down? If so you could try unplugging it wait 15 second and plug it back in. This might reset the lock.
Feb 28, 2011 | Ovens
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
How do I clean my oven? Model #RF354BXWD?
At the bottom of this is a link to the manual, it shows details starting on page 22 of how to clean.
Remove the racks and pans from the oven.
1. Move the Lock Lever to the right-the Clean position.
When the oven temperature goes above normal baking/roasting temperatures, the door cannot be opened and the Lock Lever must not be moved.
2. Set the Oven Selector and Oven Temperature Control Knob to
CLEAN.
3. Make sure the clock and Start and Stop Times all have the correct time of day.
4. Push in and turn the Stop Time Knob clockwise two or three
hours. The OVEN HEATING Indicator Light will come on. l Use two hours for light soil. l Use three hours or more for moderate to heavy soil.
NOTE: Make sure the Start Time Knob is not pushed in.
5. After the Self-Cleaning cycle is completed and the oven has
cooled enough, the Lock Lever can be moved back to the left.
DO NOT FORCE the Lock Lever. Wait until it moves easily. Turn the Oven Selector and Oven Temperature Control Knob to OFF.
6. After the oven is cool, wipe off any residue or ash with a damp cloth.
If needed, touch up spots with a soapy steel-wool pad.
Manual
Jul 30, 2010 | Whirlpool Ovens
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
I ran the self-cleaning and the door will not open.
or
Mar 06, 2010 | Whirlpool Ovens
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
When I try to start the clean cycle, I get E1 in red and -F5- in green
the oven door must be locked for it to self clean.look for a lock lever below front edge of cook top,at top of oven door.pull lever out to lock.select self clean.
Sep 29, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
91 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
