Question about Lexmark X7350 All-In-One InkJet Printer
Lexmark x5650 will not turn on. I unplugged the printer to relocate to an different area. I plugged the printer back in and it will not turn on.
SOURCE: lexmark x5650 #36 black & 37
to des_cunningham2001@yahoo.com
Posted on Feb 20, 2009
ginko
  • 19396 Answers
SOURCE: i lost the Lexmark X5650 Printer, Scanner, Copier
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Mar 05, 2009
  • 15 Answers
SOURCE: My Lexmark X5650 all in one printer displays a paper jam error
Inspect entire paper path for even a little shred of paper. All it takes to block a sensor, or hold down a "finger". if nothing at all, could be one of the sensors are faulty or unplugged.
Posted on Sep 22, 2009
pineworks
  • 4041 Answers
SOURCE: Lexmark X5650 All-In-One InkJet Printer
Hello there You can try see if this may do the job. This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
pineworks
  • 4041 Answers
SOURCE: Lexmark X5650 printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Printer will not print
If unplugging and re-plugging the printer into your computer doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x5650 cannot retrieve application list
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  4. Reboot computer.
Jan 16, 2012 | Lexmark X5650 All-in-One InkJet Printer
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x5650 printer won't come on
Try these:
  • Plug printer straight to power outlet in the wall. Bypass any surge devices or power strips as they can draw away power from the printer.
  • Properly secure the power cord.
  • Unplug the power adapter from the printer, replug after 30 seconds. The power adapter is the rectangular black box, behind the printer where the power cord is attached. Check if it's warm or cold. It can be a defective power adapter.
  • If you have access to a voltmeter, test power adapter(30V output).
If problem continues, contact Lexmark technical support.
Sep 20, 2010 | Lexmark X5650 All-in-One InkJet Printer
I have a Lexmark X5650 all-in-one printer. The power supply port was pulled out from the back and now the printer won't turn on. Do I need to buy a new printer or can this be fixed?
I strongly recommend you contact Lexmark Technical Support for assistance with that. If the problem is just the power supply of the printer, Lexmark Technical Support can send you one for free. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 30, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer does not turn on?iam pushing the on button.
Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. With the other end of the power cord still plugged in to the power outlet, the power supply of your Lexmark X5650 should have a green light on around the silver contacts. If not, you might have a defective power supply. If that's the case, I suggest you contact Lexmark Technical Support for the power supply request. If there is, plug it back in the printer all the way through and in a correct position. Printer should power on automatically, otherwise, press the power button. If printer is still not powering on, it might be defective now. Contact Lexmark Technical Support for further troubleshooting.
May 11, 2010 | Lexmark X5650 All-in-One InkJet Printer
My Lexmark X5650 all in one printer displays a paper jam error but there is no paper jam. And I can't seem to get it to disappear after turning it on and off and unplugging it.
Sep 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a lexmark x5650 and evertime I try to print something the paper will feed through on one side and not the other so it doesnt print properly. also it says paper jam. any ways to fix this??
if you have a paper jam error and you don't see a Jam it means the printer just needs to be reset.
Please try this to do a partial reset. Leave the printer on and then unplug it and leave it unplugged for about 1 minute and then plug it back in and turn it back on and see if the problem persists.
About the paper feed, first check the printer preferences, go to start, select printer and faxes. Mark the Lexmark printer, click right mousebutton and select properties from the menu list.
Check that you have set paper size to DIN/A4 and adjust your other settings as needed.
If the problem persist check if you have the latest drivers installed, if this doesn't help I think you will need to contact lexmark support.
Aug 26, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
Jun 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
262 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
