Question about Saws
I just brought scheppach 3 bandsaw but in transit i lost the instructions . Now i am not sure what the levers and knobs are for . And i dont want to damage it has i have save up for so long to buy one .And its second hand so cannot get one from shop. All help appreciated. Tony
    Guru:
  • 509 Answers
If it's a Scheppach Basato 3 205mm Bandsaw, this website has a downloadable manual...
http://www.screwfix.com/prods/30550/Power-Tools/Benchtop-Woodworking/Scheppach-Basato-3-205mm-Bandsaw
Posted on Nov 06, 2010
I am unable to remove blade
Make sure you clean the knob adjustments on your bandsaw. Sawdust buildup would cause stiffness of the knobs. Look for a manual online and follow the instructions on installing band saw blade.
Jun 29, 2014 | Ridgid Ryobi Bs901 Band Saw Replacement...
I own the bench top Scheppach m90106 bandsaw. The kevlar band in the bottom of the saw that connects the motor to the actual blade wheel has become lose, causing the saw to lose power almost immediately...
I can't find any good source of manual of your saw. I wish I can help you. I don't know kevlar band. Try calling the technical rep of the manufacturer. They should be able to assist you with that.
Sep 12, 2013 | Saws
Need help identifying my bandsaw
I made a research on google and I found Brico BS360 band saw . However, I am not pretty sure about this since there is no any other information came out. Photo of the band saw would really help. Just try posting this to different forum site .
Apr 16, 2013 | Saws
Knob for kitchaid stand mixer
I am assuming you mean the little black knob on the speed control has broken off. I will post the solution for that problem.
The speed control lever on KitchenAid mixers has a little black knob on the end (in some cases this may be white or gray). The knob is pressed onto the lever, so if the knob breaks off your only option is to replace the whole lever.
KitchenAid has a kit that will include all you need to replace the speed control lever. It even comes with instructions. Here is a link to the speed control lever kit on our website: http://www.mendingshed.com/kaleverkit.html
The lever kit includes the speed control lever (with knob), speed link, spring, instructions and a gearbox gasket.
The instructions will only walk you through how to hook up the speed control lever, so if you also need a little guidance in taking the mixer apart, and reassembling it please use the KitchenAid service manual. The manual will walk you through all of the repairs you may need on your mixer, including how to take the mixer apart and put it back together. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Remember, The Mending Shed is a Authorized KitchenAid service center, we can help you with any repair needs for your KitchenAid appliances, plus all of the parts we carry are genuine KitchenAid brand.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 15, 2013 | KitchenAid K45SS Classic Stand Mixer
Clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Sep 23, 2009 | Grizzly Saws
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
I dont know how to load my Nikon 35mm camera. I need instructions
Pull up the film rewind knob to open the back.
Drop the cartridge into the well on the left and, while rotating the rewind knob, push it back down to secure the cartridge.
Pull the leader across and insert it into any of the slots in the takeup spool.
Make sure the film perforations engage the sprocket teeth.
Alternately wind the film lever and press the shutter button until the perforations on both edges of the film engage the sprocket teeth.
Close the camera back, making sure it latches.
Take up the film slack by rotating the rewind knob in the direction of the arrow until you feel resistance.
Make blank exposures until the counter shows "1".
There's a fuller, illustrated set of instructions in the manual, which you can download from http://www.butkus.org/chinon/nikon.htm
Mar 20, 2009 | Nikon FG 35mm SLR Camera
I lost instruction book and how to work it
Use the Garmin.com/webupdater too.
to keep the system running well.
Here is a link to the manual for you.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00540-00&cID=164&pID=31946
Hope this helps
Regards.
Mar 08, 2009 | Buck BENNETT DVD GARMIN NUVI 660 -...
Aspen 870 Crib Instructions
PLEASE READ THIS WEBSITE INFO ASAP! The model 38740 WAS RECALLED! Please check your serial number with this wepage! http://www.consumeraffairs.com/recalls04/2007/simplicity_cribs2.html
Also, you can call Simplicity Inc, who made this model with Graco at 1-800-858-8323. If your model is not recalled, I'm sure they can instruct you on obtaining a manual! Good luck!! :)
Aug 30, 2008 | Graco Apsen 3-in-1 8740 Crib
My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Mar 27, 2007 | Krups 288 SensoToast Compact 2-Slice...
Saws Logo
641 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
