Question about Health & Beauty
I have a 3wheel legend pride when i press the excelerator all i get is a clicking sound and the motor unlocks but will not move forward or reverse
  • 692 Answers
Daniel It could be the throttle pot or speed pot or even the motor itself. The clicking sound you hear is the electric brake being energized when you depress the throttle. This means that you are getting power to the rear but not to the motor. If your scooter has been used alot and for a few years it could be just the motor brushes and those can be checked rather easily by removing the brush caps located near the rear of the motor housing but before the brake wich is at the end of the motor. If the brushes are worn down then you will need to change them. If they are still pretty long 1/2 inch or so then you probably have a motor issue And a tech will have to check it for you Hope this helps
Posted on Nov 07, 2010
HOW MANY OHMS SHOULD GO THRU PRIDE CELEBRITY X CONTROL ?
I have a Pride Legend XL. I tried to get the wiring diagram, but
Pride USA would not give it to me.
They told me to call the dealer instead. I had a problem with reverse throttle creep, where the brake would not engage and it kept rolling back on me.
Had to call the local dealer to do the intial trouble shooting
(who knew exactly what the problem was) to the forward reverse throttle control pot.. I was able to order the throttle pot and replace it myself.
The problem is that Pride uses some potted modules in the tiller
and the control area, although you can find pretty much
all the parts for Pride from monsterscooterparts.com,
they don't have the wiring diagram for mine either.
I am disappointed in Pride, who want to keep their
service manual with the wiring diagram a big secret from
the owners and only the dealers have it.
Oct 19, 2014 | Pride Health & Beauty
Pride wrangler pmv-600 goes in reverse on forward lever
Check the polarity of the motor harness at the controller.
Sep 28, 2014 | Pride Mobility Products PMV600 Wrangler -...
I have a pride go go ultra x scooter... I purchased it, and it had no top dash at all... I put a new throttle pot, and a whole new dash assembly... It runs great... Then I turn the speed pot to fast......
7 flash code is: Throttle control fault.
1. Check wiring for open/short circuits.
2. Check the throttle set-up.... The ohms should be very close to each other when placed checking forward and reverse on set up.
Aug 24, 2014 | Pride Mobility Products GoGo Ultra X...
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
I have a pride mobility a scooter, maxima, when attempting to move forward just a clicking soound occurs no movement
When mine does this it means she is not fully in gear. Try manually moving it back and forth a few inches and see if it clicks in.(Like moving the seat back in the car and it doesn't quite click in.) If it doesn't work take it fully back out of gear and try again. Mine is a pride victory 3 wheeler, to check the exact specs on yours follow the link below for a pdf of your user manual. See the bottom of page 34, (Troubleshooting)
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Maxima%20Owner%27s%20Manual.pdf
Hope this helps:).
May 01, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Apr 22, 2010 | Pride Mobility Products Celebrity X - 3...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
