Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Posted on Nov 07, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do we repair leaking faucets and clogged drain
    Hi. To fix leak, replace cartridge in valve. To clean out drain, Clean out trap under sink.
    Jun 09, 2011 | Blanco Classic Single Handle Faucet with...
    I have a Blanco 157-081-ST Single handle, satin finish faucet that leaks. I'm trying to get to the cartridge but don't know how to take off the handle. I've removed a single screw on the handle body but...
    If the screw you have removed is a set screw then you shuold be able to remove the handle. If it has been on there awhile you may need to pry on it with the handle in the full open state. Use something that will not mar the handle.
    Feb 12, 2011 | Blanco 157-081-ST Modera Kitchen Faucet...
    I have a blanco kitchen faucet that is about 5 years old. it seems to be leaking from inside the unit itself , problem is , trying to figure out how to get it apart to repair it.
    behind the handle there should be an allen screw under a crome cap . once you reove the screw the upper metal ring should just unscrew then there are a series of o rings that can be replaced
    good luck James
    Dec 26, 2010 | Blanco Classic Single Handle Faucet with...
    How do I remove the bonnet nut from a blanco 1-handle faucet (like their "classic" model?
    If you mean the top faucet handle, there is a small round plastic cap. You need to remove this and then remove the grub screw, handle will then pull off. Hope this is what you meant, if not post again. Thanks Paul.
    Aug 30, 2010 | Blanco Classic Single Handle Faucet with...
    The tap is leaking it appears at the bottom of the tap where it meet the sink it is a hansa single handle with vegatable sprayer with a ceramic cartridge
    Hi, there are flexible water pipes that scew into the bottom of the tap, one of these could of come loose; try tightening, or the washer may need replacing.
    Hope this helps
    Jul 21, 2010 | Blanco Classic Single Handle Faucet with...
    Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
    you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
    May 30, 2009 | Blanco Classic Single Handle Faucet with...
    How to replace cartridge on blanco single handle
    Somewhere around where the handle fixes to the tap should be a grubscrew of some kind undoing this will allow the handle to be removed this will give you access to the cartridge which can then be removed with the correct socket, obviously you will need to turn off the water supply to the tap first!!
    Jan 25, 2009 | Blanco Classic Single Handle Faucet with...
    Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
    1,076 people viewed this question
    Top Blanco Plumbing Experts
    Mack Baxter
    Andrew Bugbee
    Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
