Question about Sharp R-520LW Microwave Oven
My micro wave just stop working - Sharp R-520LW Microwave Oven
    Sergeant:
  • 252 Answers
Please be very careful when troubleshooting your microwave it can shock you even when it is unplugged from a power source. Take your digital multimeter and check your fuse. If ot is blown check diodes if it reads both ways it is bad. If you arent sure how to discharge the main cap please have a tech troubleshoot your microwave. Most likely it will be the diode if the fuse is blown. If not it is the big electrolytic capaitor shaped like an oval tin can please be careful with this component make sure you discharge it first before relaceing
Posted on Nov 07, 2010
Hi, My AEG built in micro wave has stopped working I was warming plates and it just cut out leaving an / and * on the display, I switch it off for 15mins then switched it back onit flashed 12.00 twice and...
Your microwave is not intended for use as a plate warmer. The plates may not even be microwave compatible. You may have caused the internal fuse to open or smoked the magnetron. The control board may have been affected as well.
Jan 01, 2014 | AEG MCC663 Microwave Oven
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Dec 04, 2012 | Microwave Ovens
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
When micro wave oven is in use, I can feel air coming from the door. is it leaking micro waves?
Not likely if the door seals are intact, clean, and the door is latched. The pin-holed screen that you can see through stops the microwave energy. Hope this helps!
Jan 25, 2011 | LG LMH1017 Convection Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Sharp R-520LW Microwave Oven Logo
119 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
