Question about PreSonus FIREPOD (673454000539) Audio Input
I feed firepod schematic diagram - PreSonus FIREPOD (673454000539) Audio Input
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
Presonus firepod pinouts
Try shooting an inquiry directly to PerSonus.
Feb 20, 2014 | PreSonus FP10 FireWire Recording Interface...
Need wiring diagram for cub cadet 1045
feed schematics for lt1050 cub cadet
Dec 13, 2011 | Cub Cadet Garden
I am using a presonus firepod into Logic pro 8 and it wont recognize the audio I am trying to record into it. I recognizes the Firepod which is chosen for input and output (output works fine). However when...
Have you been able to successfully do this in the past? What software are you using to try to record with? Does it seem to recognize the guitar in the software, just will not react, or does it not appear to see it at all?
Thanks, let me know and I can help!
Tim
Sep 16, 2010 | PreSonus FIREPOD (673454000539) Audio...
My Win7 does not recognize my 2005 Firepod, when i get to the point that it tells me to connect it and turn it on, it does not continue installation, it just keeps repeating for me to plug it in and turn...
Win 7 is probably incompatible with the Firepod. Others find the same thing and unless the Firepod manufacturer writes new drivers, it will not work with Win 7.
Probably the best course of action is to go back to XP or the previous OS you have used with it.
NEVER switch operating systems without checking that hardware and software is compatible with the new OS.
Microsoft is notorious for incompatibility of new OS versions such as Vista and now Win 7.
Jan 12, 2010 | PreSonus FIREPOD (673454000539) Audio...
I need to replace the headlamp wires on my 1992 HD heritage classic. Is there any diagram and how to directions available
white is high beam ,yellow is low beam, black is ground. yellow also feeds the passing lamp switch,blue from the lighting circuit breaker feeds the light switch.the factory manual has the entire bikes schematic.
Sep 03, 2009 | 2001 Harley Davidson FLSTC - FLSTCI...
Not syncing
Could be a bad cable, bad firewire card in computer, or the unit is damaged.  Might want to connect the unit to someone else's computer with a new Firewire cable.  If this doesn't work, chances are that the unit is defective.  I have the same problem right now and I'm having to send the unit back to Presonus.  They charge $85 for parts labor and the return shipping.  The replace the entire board, so it's like getting a new unit.  Hope that helps.
Jackie
Oct 17, 2006 | PreSonus FIREPOD (673454000539) Audio...
Picture problems
you have a vert sweep colapse. Fisrt thing is to get a schematic diagram and find the vert. output Ic and the clamper diode. Measure the voltage on both sides. If its low then its apossibility that the Ic was drawing loads of current and blew out the b+ feed resistor. Look on the schematic and trace back the voltage line from the vert output ic back to the sweep power supply on the secondary of the flyback transformer. check the limiter resistor to the feed and if its open replace the cap right there the resistor as well as the vertical output Ic ALL AT ONCE!!! If you dont you will cause it to go out again in a short time. Good Luck.. If you post the vert part of the schematic I will be more then happy to assist you with this repair.
May 01, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
Open Questions:
See all PreSonus FIREPOD (673454000539) Audio Input Questions
PreSonus FIREPOD (673454000539) Audio Input Logo
322 people viewed this question
Top PreSonus Televison & Video Experts
Electro Med Services...
Are you a PreSonus Televison and Video Expert? Answer questions, earn points and help others
