Question about Bose (321GS) System
Bose model PS 38, the light is flashing from green to yellow and I am getting no sound out of the speakers. I hooked the speakers directly up to the TV so I know they work.
worldvet
  • 859 Answers
SOURCE: Connecting Dell speaker system to TV or console
If you have a coaxial out on your TV and a coaxial in on your Speaker system that is the way to go to experience digital surround sound. Radio Shack, etc. has coaxial cables in the appropriate size. If you go to Radio Shack, etc. bring along your speaker system's model number as well as your TV's model number.
Hope this gets you going.
Worldvet
Posted on May 21, 2008
ward_knutson
  • 64 Answers
SOURCE: Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Posted on Nov 25, 2008
cjackHD
  • 71 Answers
SOURCE: Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Posted on Jun 18, 2009
MarineTech1
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
I have a Bose lifestyle 38 and whenever I watch a show with a lot of background sound - ie music in a movie or crowds cheering for sports, it overwhelms the voices of the actors or the sports casters. How...
What makes background sound comes out from Bose lifestyle 38 system is because there is jack cable or a cable that has a jack mouth that brings out a mono sound is being inserted..
Mono cables, when inserted inside a wrong input,it's makes the sound comes out with a background noise just like the one you can hear from it now..it seems as if you are not using the right cable for connection..
To resolve these issue, you will need to use the right cable for connection, by doing these,you will get a clearer sound from you Bose lifestyle 38..
Also it can be from the settings inside the Bose lifestyle 38...So you will need to check both sides to resolve this issue..
You will need to use the manual to know the right cable and the right setting for clear volume..
You can download the user's guide from the below link..
http://www.retrevo.com/support/Bose-Lifestyle-38-Series-III-Home-Theater-Systems-manual/id/524dj979/t/2/
Hope it helped.
Thanks for using fixya..
Aug 15, 2011 | Bose Audio Players & Recorders
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
We want to hook up an HDMI dvd player to the tv and have the sound come thru the Bose Lifestyle 38 (older model, did not come w/the HDMI converter that the 48 has or newer systems come with). We are not...
The best way to do this is to take your OPTICAL AUDIO OUT from your TV - (if it's a newer TV) - plug it in to the OPTICAL AUDIO IN on your BOSE system, then use the 'TV' source on your Lifestyle 38 to get the sound from. I have sound for X-Box, DVD player, Blue-Ray Player and Wii being pushed through the TV back to the BOSE and it sounds great. I don't have to change the source on the BOSE very much either - except when I listen to stored music!
Sep 27, 2009 | Bose Lifestyle 38 System
Bose 123 system and Samsung LED TV problem.....
yes use the Av cables for this connection . at the back of the TV there should be video in and Audio in connection.
for video its usually the yellow pin so yellow will go with yellow tv & m system
just follow colour code
ansd now u will get visual on the screen .
good luck dude
Sep 08, 2009 | Bose Cinemate Digital Home Theater System...
Aug 18, 2009 | Bose (321GS) System
Jul 28, 2009 | Bose Lifestyle 38 System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose (321GS) System Logo
218 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
