Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
FVD interface failure is flashing. How do I reset the water heater?
  • 760 Answers
Is it flashing 2-3? Try this: You can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Nov 06, 2010
  • 5 more comments
  • joel838
    joel838 Jul 10, 2012
    I can't believe that worked! Thank you!
  • kolbymaddie
    kolbymaddie Jul 21, 2012
    Thanks Tom! This fixed my problem last year and it has been fine until now. At this point, it seems like I have to reset it after every shower! What do you think is going on? Thank you so much for your help!
  • Harold kim Sep 06, 2012
    Totally worked! Thanks
    This totally worked!
  • thatbeerguy
    thatbeerguy Dec 23, 2012
    This worked on our Rheem. Thank you! Hot water for the holiday's!
  • Don Pyka
    Don Pyka May 07, 2014
    It worked on our Richmond! THANK YOU!
  • Diane Meers
    Diane Meers Aug 05, 2014
    Diane Meers It worked on my GE Smartvent! Awsome. Thanx lots. :)
2 Suggested Answers
SOURCE: rheem water heater 42vp40sf and
Call Rheem
1-800-432-8373
TRD is flammable vapor system. Typically there is a glass bulb or fuse located in the combustion chamber.
See example image:
http://waterheatertimer.org/images/FV-TRD-glass-fuse-300.jpg
Remove the burner and look for the evidence of broken glass bulb that holds the air intake open.
Air intake is located bottom of combustion chamber, and bulb breaks causing metal plate to snap upwards and close off air supply to combustion chamber.
Rheem will have exact part number and possible instructions. Other people have wedged the air intake open to get system working again, but I do not know if that will work with your model water heater with electronic control. Working around the FV system exposes home and people to flammable vapor ignition and explosion when water heater is exposed to flammable vapors.
Example manual with illustrations.
http://waterheatertimer.org/pdf/Test-if-thermal-release-device-needs-replacement.pdf
Clean burner and pilot orifice and combustion chamber while burner parts are removed. Also clean air intake.
When burner is removed for cleaning, the access door gasket might need to be replaced.
Your product manual and/or Rheem will have that part number.
Posted on Sep 24, 2011
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 42VP50FW flashes 2-3 (FVD Interface/miswiring) wont ignite
Your safety device is probably sensing humidity as vapor. That's what ours seems to do. The replacement FVD is Rheem AP13447-3 Flammable Vapor Detection Sensor. It's down near the floor, can be pried off with a screwdriver, and unplugged. It needs to be replaced, since the heater will not ignite if its unplugged or too high resistance (detecting gas, or, if broken, moisture after a rain).
http://www.amazon.com/gp/product/B007IB22NM
Jan 02, 2012 | Water Heaters
Rheem water heater 42vp40sf and the fvd interface failure code is flashing. how do i fix this?
Call Rheem
1-800-432-8373
See example image:
Sep 23, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I can't get my pilot light turned on. I have a Rheem powervent water heater and I can't turn it on. I keep getting an error message that says "FVD interface failure/miswiring". What do I have to do to...
Most likely your flame sensor wiring is partially burn't or has an open circuit fault that's giving you the error message. This wire starts at the gas control and ends next to the pilot assembly. It can easily be replaced using a small wrench to unscrew the end connector from the control and the flame sensor rod at the pilot assembly. Call Rheem and see if the water heater is still under warranty, but even if it isn't they can most likely order the part you need for you. The phone # is on one of the data decals on the side of the water heater tank. They will need the model # and serial # to order the part. Be sure you unplug the unit before working on it! Douglas
Sep 28, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
No hot water, unit will not fire,
It sounds like the Flame vapour sensor has tripped. Have you been painting in the basement recently or have and pait thiner, bleach or any other flamable material in the same room?
You will have to air out the room for at leaset 24hrs to get the fumes out and then try reseting the tank. If this doesn't work you need to call in a service technition to reset the FVIR sensor
Jul 02, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
What does fvd interface malfunction mean
richmond lock out how to reset or restart my hot water heater
Oct 14, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
40gal richmond powervent wont light. code says fvd interface failer what does that mean????????
sounds like the circuit board is bad,, when you turn on the unit does the fan come on first if not you need a circuit board, depending on the age it might be cheaper to change the whole unit
Jun 13, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
3,421 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
