Question about GE Security Simon 3 Wireless Home Security System
Bad battery in fire alarm sensor, please provide steps to bypass the sensor, which is sensor 10 group 26
    Novelist:
  • 134 Answers
Why do you want to by-pass the sensor? It's there for a reason after all. If you KNOW the battery is bad, replacing it should bring the unit back into proper operation. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid LandCamera"The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Posted on Feb 01, 2011
I tried to bypass my ignition now my bike will fire but it wont start or run
Hi, Timmy and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
motorcycle turns over but wont start
What to do When Your Motorcycle Won Start
troubleshoot motorcycle not starting
Mar 18, 2016 | Motorcycles
Bajaj 180 will not fire
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD Bajaj Pulsar 180
Jul 27, 2014 | Bajaj Pulsar 180 Motorcycles
Front cyc no fire 2008 v star
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
No Fire
02 vstar classic dead front cylinder
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jul 01, 2014 | 2008 Yamaha V Star 1100 Classic
Engine not firing up with starter
1. Fuel tank empty.
Damn bike won start BMW K75 K100 K1 K1100
K11 Owners Group View topic 1995 K1100LT not starting no spark computer...
http://www.rbracing-rsr.com/downloads/K1100LT_RS_Repair.pdf BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Feb 23, 2014 | BMW K 1100 LT Motorcycles
2010 streetglide new fuel,plugs,bike pops and thuds no fire
Hi Richard, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 01, 2014 | 2010 Harley Davidson FLHX Street Glide
Wiring diagrams
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Harley Davidson Wiring Diagrams and Schematics
Harley Davidson Sportster error codes and how to access them Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Apr 30, 2013 | 2001 Harley Davidson XL Sportster 883...
No fire to spark plugs
Hi Bigeasy1972, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
7. Discharged battery, loose or broken battery connections especially the "NEGATIVE" cable to the frame.
For a primary suspect please visit the website below. Good luck and have nice day.
Jul 03, 2012 | 2003 Harley Davidson FLHT Electra Glide...
Won't start. turns over but acts like not getting
first make sure the security lights not on if thats good try to get a fuel pressure reading then if that checks out see if the engine is getting spark if no spark the crankshaft positon sensor maybe bad
Jul 15, 2009 | 2005 Pontiac Grand Prix
Codes
p0513 invalid skim key
do you have an aftermarket alarm that is "remote start" compatible? if so, the skim is reading that the car is starting without a key, but the alarm module is allowing it to start, bypassing the skim module.
p0517 High battery temp sensor.
Either the battery is gettign to hot and/or it has a bad sensor.
Mar 27, 2009 | 2003 Dodge Neon
GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Oct 06, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
63 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
