Question about GE Heating & Cooling
I HAVE A GE MODEL#APE08AKM1 AC MY COMPRESSOR AND CONDENSOR FAN WONT START THE DISPLAY HAS A E4 WHAT DOES E4 MEAN
    President:
  • 2,777 Answers
E4 means the control module, the "brain" of the unit basically, has error-ed out and failed. You can attempt to kill the power to the device for 5 minutes or more, then restart and many times it will get that module "kick-started" so to speak.
If not you will unfortunately need to get service scheduled on the device, there is no simple fix beyond that.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 06, 2010
2008 kia sorento ac compressor/condensor fan wont engage
check relay and fuses and a/c switch on front panel inside the car
Oct 20, 2017 | Kia Cars & Trucks
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
I have an airconditioner model APE08AKM1, but the compressor dont run, please help me
CUAL ES LA MARCA DE TU EQUIPO, TIENE REFERENCIA DE LOS ERRORES? EN LA PUERTA DEL EQUIPO?
Apr 29, 2014 | Heating & Cooling
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
How soon after replacing the condensor fan, is it supposed to kick on?
Condensor fan should start when the compressor starts. If the condensor is hot at top and bottom, turn the refrig off and check the fan for power, should spin freely by finger, and coast to a stop.
Good Luck,
Bill
Aug 17, 2012 | GE Refrigerators
Maytag refrigerator model msd2651heb not cooling. Hear fan running but not condensor
if you mean the compressor isn't running most likely you have a bad start device part 67005560,pull out machine unplug it and remove the bottom back panel,look at compressor,pop off metal clip and remove cover on the side of compressor,slide off the device and shake it,if the device is cooked you'll hear pieces rattling around inside it,install new part,if it still doesn't start could have a bad compressor.
Jul 14, 2012 | Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Condensor fan runs but the compressor wont start
Either you have abad comoresor or abad compresor relay ,i will try to replace the relay first(if you don't have away to check the compresor) wich is cheaper (about $20 for the part)If doesn't work the compresor is burned or stuck.
Apr 20, 2009 | Refrigerators
Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
487 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
