I have a 46 inch flat screen Sanyo tv. The left side of turns goes black on & off. If you pull back on the tv it clears up temporaily but when I let go it still flickers black.
    Sergeant:
  • 252 Answers
Check the caps in the High Voltage section. The voltage needed to ignite the gas to inside your screen to illuminate the whole screen is being depleted before it has a chance to light up your screen. The problem will be in the capacitors in your set.
Posted on Nov 06, 2010
My tv is a 42 inch lcd sanyo the left side started having vertical lines andn then fuzz when turned on then it slowly started staying that way and going farther across screen if you move the tv around it...
Its probably a bad ribbon cable on that side of the tv. if u put pressure on that side ( on the plastic) it may resovle the issue. otherwise it could be a bad tcon board and the tcon board would need to be replaced.
Dec 15, 2013 | Sanyo DP32746 32 in. LCD Television
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Dec 15, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
How do I fix a A black screen on the left side of
Hello; I do a lot of Sanyo repairs and have seen this problem several times. The left side may be black always or sometimes. In either case the LCD panel is bad. the part from Sanyo was last $1000.00. There seems to be some refirbs or knockoffs for $400. Time for a new set. John
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
I have a sanyo LCD 46 inch tv the model number is DP42848 and the left side of the screen is black when it is on. Even when left on for a while it does not clear up. we are still able to see what is behind...
It could be the video processor board (T-connector board) or its ribbon cables. This board has two ribbon cable that supply each of the two circuit boards for the LCD glass. One for the left and one for the right. If one of these cables has become disconnected, then only one half of the screen will work. To check the cables, you must remove the back of the TV. The video processor board is under a metal cover. Remove the 4 screws to expose the board. Check the one input and two output cables to be sure they are properly seated. If one side of the screen remains dark, the problem may be in the video processor board itself. You can probably get one on ebay. Otherwise the problem will be in the LCD glass circuits and it can not be fixed.
Jan 20, 2011 | Sanyo DP42848 LCD TV
We have a Sanyo 46" 1080P lcd tv that has been going black on the left side for about 2 months now ,it's like a black square on the left side , can you tell me what this is and what the cost would be to...
We've had the Sanyo 1080p Flat screen TV for about a year and a half and the right side of the TV is black when we turn it on and after about 45 minutes in brightens. Sometimes it still has lines flickering throught he uper right.
Solution?
Oct 05, 2010 | Sanyo Televison & Video
I have a 46 inch sanyo lcd 1080p that is only 2 years old. A few months ago we started getting a black screen only on part of the tv. It would show up off and on. some days all the time and others not at...
I'm having the same problem with the same TV. I called around to repair shops and I guess it's fixable. Haven't taken it in yet but I was told it most likely is a bad module. But this seems to be a really common problem with this television
Feb 04, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo 46' flat screen tv - has issues like all of a sudden it will make a high pitched noise and then the TV goes out - the picture freezes and then the screen goes black
our Sanyo Flat screen tv freezes, makes a loud noise, then turns off then back on automatically. It does it more frequently while watching an exciting part of a movie
Jan 10, 2010 | Sanyo DP46849 46 in. HDTV
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
