Question about LG LRBN20510WW Bottom Freezer Refrigerator
Top refrigerator is not working, freezer is OK. When I unplug then plug it in again the indicator light for the refrigerator comes on but after a few minutes goes off, During the ime it is on there is a very low sound similar to a dull clicking. I checked to see if there was ice blocking the vents in the freezer area but there was none.
  • 1 more comment
  • jkevdwyer Nov 06, 2010
    I don't see where I can access the fan. How do I get access to the fan?
    no, its LDC2272
  • jkevdwyer Nov 07, 2010
    Previously replied "no its model LDC22720" . Never received another response. What's up?
    President:
  • 2,777 Answers
Your refrigerator gets its cold air from the freezer by way of a fan that transfers air past the freezer coils to the refrigerator. If the fan isn't working the refrigerator will not get cold. I your coils in the freezer are freezing up this will also stop the flow of air to the refrigerator. The first thing to check is the fan.
It definitely sounds like it has failed or is failing at least..
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 06, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Nov 06, 2010
    Please verify, is yours a model # LRBN20510WW fridge by LG?
    Just want to make sure before I give you instructions here..
    Tim
  • Tim Grayson
    Tim Grayson Nov 07, 2010
    Sorry I ran somewhere for a bit, getting the info now, will post within 10 minutes here the info..
    Tim
  • Tim Grayson
    The fan is extremely difficult to get to on this model. You need to disassemble the back of the fridge to gain access to it. I do not recommend attempting this unless you are an appliance repair person by trade. I am quite sure this is what has failed though, the evaporator fan motor is the culprit, it has most likely failed. You can get an accurate quote from an appliance repair person in your area with this information that way they do not need to spend time diagnosing the issue which will save you a good deal of money.
    I would not attempt to do this on your own though, you could easily damage the fridge further and then it would be exponentially more expensive to fix.
    Let me know what you think there, sorry about the delay.
    Tim
Maytag plus frig bottom freezer
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 17, 2010 | Maytag MBF1956HEQ / MBF1956HEW /...
Ref. is not as cold. No light on temp control
Sounds like a control board issue. When you unplug the unit your are resetting the control board. Then after a while one of the relays on the board is getting stuck again.
Sep 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator not working
take and hold the top two buttons untill the unit beeps and the it should work ok.
Mar 25, 2009 | Refrigerators
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
May 19, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Power light flashing on & off
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Jan 08, 2008 | Zanussi ZEBF250W Bottom Freezer...
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
91 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
