Question about Mitsubishi WS-55809 55" Rear Projection Television
I have a Mitsubishi Medallion HDTV 1080 55 inch that when I push the device button to change the input, it locks up the whole tv and I have to reset the system just to turn it off. How do I fix this problem?
    Brigadier General:
  • 8,909 Answers
You will most likely find, on the power supply board, a 5volt regulator that supplies the microprocessor. It is on a heatsink and is protruding perpendicular from the board on a heatsink. If you examine the copper side of the printed circuit board, there will be dry joints on the three pins making a bad connection. If you can, replace the regulator and your problems should be gone.
Hope this helps.
Posted on Nov 06, 2010
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
How to change inputs
Just press input button on the remote or the TV.
Sometime they label input as Source.
www.aaatvservice.com
Aug 13, 2014 | Mitsubishi LT55164 Unisen Medallion 55...
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
TV will not unlock channels over TV14
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
These steps are actually for the rear projection models, but I hope the work for dlp plasmas as well.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
When I push the device button on the remote, I
I had this same exact problem with my WD-62627. I got mine to work by re-initialing the tv. I could not believe this worked. Try this, 1) turn on the TV
2) press MENU 2,4,7,0 then ENTER
3) the TV should INITIALIZE
4) Press the front reset button on the front of the TV.
5) should work again....if so.....
6) email me at Larry1965@hotmail.com to thank me. :)
Dec 30, 2009 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi Medallion rear projection lost signal from all devices
Have you fixed this problem yet?. I seem to have the same issue.
Sep 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Tv keypad on front is locked and can't find remote
after reading a similar issue on fixya about another person having a similar problem and holding down the setup button for 10 seconds, I tried it on my television (although I don't have a setup only a menu button) and it worked. Thanks.
Jan 13, 2009 | Televison & Video
Wd 62725 medallion
have you tried the reset button on the front panel ? you need something small like a paper clip, or pencil to push it in.
Jan 03, 2009 | Mitsubishi WD-62725 62" Rear Projection...
No Remote need to set up for DVD Video (Mitsubishi Medallion HD 1080)
What you do is match color with color, just make sure if you are putting in Video 1, 2, 3 etc. then you have to set your tv to that input with that Device/input button.
Mar 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsu WD 52525 confusion
to change the channels on the vga side you need a tuner that has separate component inputs and you would change the channel on that
Jan 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
