Question about Relisys RLT1720 17" LCD Monitor
After two years of using monitor, I turned my computer off one night. The next morning I turned in back on and all I got was a white screen. The monitor never changed the screen, just white with a grayest line down the middle. I turned the monitor off and on, still nothing. And I even tried another cable on the back of the monitor. Still nothing. What could cause a monitor that's never been used during a storm, or dropped or bumped to just stop working.
SOURCE: Cannot turn off Auto Adjustment... message.
i has same problem and I have no idea how to disable. :(
Hope someone know how to help us out!
Posted on Mar 01, 2008
SOURCE: Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Posted on Jun 19, 2009
SOURCE: Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Posted on Feb 08, 2010
SOURCE: I got horizontal lines occasionally across my
try to open back cover and remove / insert all connector that you can found including ribbon wire check also soldered side for possible lost contact.
Posted on Apr 10, 2010
Testimonial: "Have tried this,one small ribbon that connect to the LCD panel was loose,small plastic rod was holding it,it was broken from heat,very unusual connection,I reseated with platic rod,the monitor works fine since that date."
Oct 01, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
May 27, 2009 | HP vs17c 17" LCD Monitor
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
Jan 20, 2009 | HP Pavilion F1703 17" LCD Monitor
Aug 30, 2008 | Gateway FPD1765 17" Flat Panel LCD Monitor
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
96 people viewed this question
