Question about Simplicity 7250 Deluxe Vacuum
My upright will not start. At first it would start only sometimes now not at all. I was thinking the on/off switch but would like you opinion.
My Sebo vacuum cleaner makes a whistling noise when standing upright
similar to the air relief on my dyson think it is so they don't burn motor up
Feb 17, 2015 | Sebo Automatic X4 Extra Upright Vacuum...
When I turn on my dyson animal vacuum the red light flashes on and off and there is no suction
I think you have a blocked pipe somewhere. I use a large marble to drop through the pipes to see where the problem is.
Mar 11, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Same here - but think the switch is the problem
power is the switch and the agitatior is the belt.
Jul 16, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC04 not working
Have you trod on the cable at all, sometimes the cable breaks inside the sheathing, test by switching on and wiggling cable where it enters machine, if it starts then thats your problem, easy to fix, disassemble switch, cut off and discard 6 inches of cable then reattach the reamaining.
May 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
No power to Hoover Wind Tunnel Vacuum
the problem is likely the switch a shot of wd40 should fixed it
Oct 09, 2008 | Hoover U6630-900 WindTunnel Bagless...
Problem starting
This can happen if you have an intermittent short in your cord. Try plugging it in and then wiggling the cord around where it goes into the body of the vacuum with the switch set to "on." (If you're not sure whether it's on or off, just click it back and forth occasionally.)
If the motor kicks on there's a short, which usually requires a cord replacement. If that's the case, it's a relatively simple fix for most dyson models.
If not, you could have a short in your switch or somewhere else in the electrical system of the machine.
-R
Aug 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
It seems the off/on switch is broken
Remove the tools from the front of the tool storage. You will find three screws recessed in there, two on the bottom and one at the top. Once removed, the tool compartment will slide out and the switch will be accessable.
You should be able to find a switch in any vacuum repair shop.
NOTE: Some models have FOUR screws. Two on the top and two on the bottom. They should be easy to find.
Jan 12, 2008 | Hoover U5753-900 WindTunnel Bagless...
Won't start
Could be that the cord is bad, the switch button isn't depressing the switch, alot of times pulling the plug out of the outlet by the cord rather then the plug will stretch and break a wire. Sometimes this switch button breaks and then won't turn it on when depressed.
Nov 19, 2007 | Eureka Whirlwind 4480 Upright Vacuum
Vacuums Logo
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
