Question about Whirlpool WTW5300SQ Top Load Washer
Whirlpool WTW5300 SQ Water leaking...Help!!
I have a Whirlpool WTW5300 SQ washing machine and it just started leaking water out the front. We checked it out and noticed it was leaking from a white plastic part under the washer. Possibly the pump? How can this be fixed? Please help!
Thanks!
  • Anonymous Mar 21, 2014
    water under the machine all over the floor
  • 413 Answers
The water pump is the front and has probably failed.
REMOVE POWER
To access the pump, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. Insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white or gray in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The pump is mounted to the motor with two spring clips. Look at the face of the pump for any signs of melting or blistering. (grey bubbling)
Posted on Jun 15, 2008
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool washer wtw5300 rinse water not emptying at all
pull pump see if it is blocked see if you can spin it
Feb 25, 2012 | Whirlpool Washing Machines
Washer went to a spin cycle and would not spin! Has a tank full of water and only hummms: Will not do anything in any cycle? Water pump or something else? WTW5300
I have had a similar problem . It turned out t be an obstruction in the pump. If your gonna get down and dirty with this machine i suggest testing the motor while your there. If that's fine ? Go ahead and check the pump.
Dec 26, 2010 | Whirlpool WTW5300SQ Top Load Washer
How do you take the top off a whirlpool sq 9030pq5 washer
look on the back there should be screws it hooks in the front and metels screws hold the back most likely
Jun 21, 2009 | Whirlpool LSQ8000 Top Load Washer
Water is leaking from my wash machine
Ifit is from the front middle of the unit that is the water pump they are made of plastic and can start to leak best was to check is to tip the unit back a little and look
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Leaking Water
check your rubber bellow you might have had something go threw it.
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking out slightly from detergent dispenser draw and is starting to rust down left hand front side of machine,checked all water supply and drain hoses but leak appears to be coming from high up...
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
Jun 21, 2008 | Whirlpool Washing Machines
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Whirlpool WTW5300SQ Top Load Washer Logo
466 people viewed this question
Dan Webster
Dan Webster
Sal De
