Question about HP OfficeJet 4255 All-In-One InkJet Printer
Cartridge error the ink low..i remove the cartridge,then refilled it,then reinsert the cartridges..the front panel warn remove and check the left cartridge..remove and clean the cartridge with dry cotton cloth,then reinsert it..the next error in the front panel is Cartridge Error: see product documentation.. ..what is the problem? ..what i have to do..?
  • 3 more comments
  • Owizzy Jun 16, 2008
    the ink low..i remove the cartridge,then refilled it,then reinsert the cartridges..the front panel warn remove and check the left cartridge..remove and replace with new cartridge yet still got the same message: remove and check the left cartridge..
  • ind_pachi Jun 24, 2008
  • Anonymous Jul 12, 2008
    I HAVE THE SAME problem as well
  • Anonymous Dec 29, 2008
    Remove and check right cartridge
  • Anonymous Jan 09, 2009
    I replaced the old cartridge with a new one, still same problem
Cartridge error 4255 all in one hp officejet how can this be fixed ?
Posted on Nov 10, 2008
    Scholar:
  • 107 Answers
Hi ,
hp is not recomanded the rifilled cartridges with printer .
& also printer is not detected refield cratridge as a full or new cartridge please check with new Hp orignal cartridge
it should be working ..................
if this information is useful for u please Rate me.......
Posted on Jun 15, 2008
Ink refill costco hp printer C4780
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena, the 2nd video provides suggested cartridge prep/handling instructions when you return the cartridge for refilling:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
If the new (or refilled/reman/compatible) HP 74, 75, 74XL, or 75XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. If you run into a problem where the ink cartridge is performing marginally and blocks printing (via the Red X), you can bypass the error message (usually only 1 time per clearing action):
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. You can also run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test).....go to www.inkjet411.com for more information on your specific printer model.
Feb 16, 2013 | HP Photosmart C4580 All-in-One InkJet...
I have just had my cartridges refilled and now have reinserted them in printer but it keeps saying remove and check colour cartridge (which i have done lots and lots of times), help please
Ink cartridge contains Ink tank, electrical circuit & print nozzles.
Adding ink to ink tank is called refilling, if any fault in circuit/nozzles will indicates the cartridge error.. Before refilling check cartridge health condition.
In your case its sure that cartridge faulty, go for new one..
Nov 10, 2012 | HP PSC 2355 All-In-One InkJet Printer
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
    Hi
    When a non professionals refill there cartridges
    air bubbles are left in cartridges durring refilling process
    so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
    check here how you can refill it your cartridges with no errors on your printer
    In case I had help you pls vote me
    Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
    We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
    Hi there
    Dell Printer 944 error message 1102
    Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
    Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
    Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
    be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
    report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
    Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
    This post is in no way a validation of refilling ink cartridges.
    Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
    Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
    running out of ink.
    Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
    remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
    getting “low ink” messages.
    To disable “Ink Alerts” on Dell inkjet printers:
    1. Open the Dell printer software (All-In One Center, Tool Box, etc)
    2. Go to Settings
    3. Advanced
    4. More Options
    5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
    ink alert only when the cartridges are almost empty.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 23, 2010 | Office Equipment & Supplies
    Can one reset the Lexmark P6250 printer refilled cartridge?
    No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
    Dec 28, 2009 | Lexmark P6250 All-In-One InkJet Photo...
    Dell a940 error code 50c
    From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
    Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
    Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
    Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
    if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
    good luck
    have a nice day
    Jul 08, 2009 | Dell Office Equipment & Supplies
    I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
    If you turned the machine off and replaced the cartridge, you can get this error.
    Could you try the following procedure below please to clear the error, thanks.
    1. Turn on the unit.
    2. Open the top cover to access the print cartridges.
    3. Remove the new cartridge that is causing the message.
    4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
    5. Press the 1 on the numeric keypad of the HP product.
    If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
    follow the steps below:
    2. Open the top cover to access the ink cartridges.
    3. After the cartridges stop moving, unplug the power cord.
    4. Remove both cartridges and close the top cover.
    5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
    6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
    7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
    Hope this helps
    Regards.
    Apr 18, 2009 | HP Photosmart 3310 Printer
    How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
    You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
    Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
    HP OfficeJet 4255 All-In-One InkJet Printer Logo
    861 people viewed this question
    Ben Johnson
