Question about Dryers
I have a 12 + yr old whole house attic fan requiring a motor replacement: L.L Building Products Model D0832B3081 9 + yr old whole house attic fan requiring a motor replacement. 12 volt, 60hz, 4.5amp, 900rpm, 1/4 hp. Thermally protected l, E62862 capacitor-10 MFD/330 VAC, com white, high-black, low red. Can you assist.
  • dan turkstra
    dan turkstra Nov 07, 2010
    What is it you need help with finding a motor ? If so look up Granger supply I can promise you they will be able to match one up . Hope this helps
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: wiring diagram?
They ain't power leads. They carry heat element current from the cent sw when the motor is running.
Posted on Jan 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Posted on Oct 18, 2009
Testimonial: "I did determine it to be the cetrepetal switch..specifically the slide for the weights was heavily gummed up with dryer belt dust. It works now."
  • 39 Answers
SOURCE: I have a 12 yr old dryer, model lgr 5636 eq2, it
could be the element or the fuse on the element box. Check also to be sure there is 220 volts entering the dryer with an ohmmeter...
Posted on Jan 17, 2011
  • 207 Answers
SOURCE: I have a magnatek, 115v.
Just wire up the black wire and cap the others. This will allow the motor to run on high at all times. You have a variable speed motot. Tie the white wire to your commom and the black wire to your source.
Posted on Jul 01, 2011
I need a belt for a very old attic fan. The belt number is 4689, the Model # is BV24, Serial # N and Catalog #BV2458
I have an old robbins and myer attic fan. The motor is bad and there is no sticker let on the moter saying what hourse power or voltage the fan is. The model number is BV24. I couldnt find anything on the web about this model. Does anyone have a clue what kind of motor i need
Aug 11, 2013 | Broan-NuTone N-GF900N Gable Fan Attic Fan
We have recently purchased an older home, built in 1931. There is a whole house fan in the attic that we would like to get working again. We do not know when the fan was installed or who made it - however,...
What and interesting situation. I have seen installations like what you describe, but not in a residential application. Industrial applications that had very high ceilings and in very old apartment buildings, But not in single family resident. I suspect, that the previous owners "acquired" it through unusual circumstances.
In any event, 1/3 horsepower electric motor is not that hard to find. The real key is getting the right rotation, so the blades will pull the air up and out instead of in and down. Remounting a new motor coupled with the right pulley size for a fan belt ,can control the speed of the fan. Rarely are hold house fans direct drive. Which may be the case with yours, I don't know.
As far as a new 1/3 Hp motor is concerned, I would recommend Grainger Industrial Supply
http://www.grainger.com/Grainger/wwg/start.shtml. They have locations throughout the country and their staff is knowledgeable. They can probably help you with designing a belt & pulley system, to control the speed, if necessary. Keep in mind, 2-speed motors are also available.
Redesigned properly, you can do away with that horrendous shaft.
Hope this helps steer you in the right direction. If nothing else, food for thought.
Apr 28, 2011 | Heating & Cooling
OLD wall timer Model E1020 ticks really loud
You probably can't get the existing mechanical timer to operate any quietier, since it's old and likely starting to wear out. You can either swap the timer out for a new automatic digital timer, or install a standard single pole switch in its' place.
I believe the code you refer to regarding the fan having to be wired onto a timer switch was a local requirement from many years ago.
Some local jurisdictions have impossed more stringent requirements, but frankly, having an exhaust fan is normally a good idea. If the fan is vented into the attic space, it can cause some serious problems in cold weather with condesation of the warm, moist exhaust air.
Building Code requires that bath fans be piped/vented to the outside of the house and not into the attic space.
There are newer preset timer switches that will turn on the exhaust fan for a fixed amount of time, based on which button you push. These are great as they will run the fan long enough to remove condensation from showers, etc.
If you're going to replace the timer, disconnect or turn off the breaker or power to the switch. Then simply install a new timer or switch by connecting the black supply wire to the bottom of the single pole switch, or to one of the black leads of the timer. Then connect the black wire going to the fan to the top screw on the single pole switch, or the other lead on the new timer. The white (neutral) wires should already be connected with a wire nut inside the box. Connect the ground wire to the ground wire in the box and if the switch box is metal, attach the ground wire to the box with a green grounding screw too.
You can now operate the fan with either a manual on/off switch or the new digital timer, whichever you chose to install.
Sep 04, 2009 | Heavy Duty Intermatic Wall Switch Timer...
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Dryers Logo
455 people viewed this question
Top Dryers Experts
