Question about Dynex DX-L32-10A 32" LCD HDTV
The TV (32" Dynex flat screen) will not turn on.
  • 476 Answers
Hello, it does not power at all, means not eaven a power light blinks in the front of the TV, which also means there could be no power getting to the TV through the cheater cord, or a completely busted power supply due to shorted power regulators, lightning damage or surges in the power line. The easiest is to check the outlet, the power strip braker if you are using one, the power cord going to the TV. The rest of things would be inside the TV(power supply and power regs etc....)
Posted on Nov 06, 2010
  • cassibell Dec 15, 2010
    if it were hit by lighting how easy and cost would it be?
    thanks
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I just set up my new TV and it's working but the picture doesn't fill up the screen. How do I correct this?
Most TVs will have a display button the the remote that when you push it, it changes the display, that or zooming in should fix your problem
Aug 05, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Mar 06, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
What is the device code for a dynex 32" flat screen for a dishnetwork remote
We would be happy to help you with getting your DISH Networkremote to control your TV. Press and hold the TV button located on the top ofyour remote until all mode button back lights come on, then release. Usethe number buttons to enter the codes for your Dynex TV; here some ofthe codes we currently have: 538, 720, and 115. Press the pound (#)button. To check that the code works try several different functions on theremote to make sure it will properly operate the TV. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, pleasetry the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 24, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I need a remote code for a Dynex tv for dishnetwork remote for a 32 inch tv
We would be happy to help you with getting your DISH Networkremote to control your Dynex TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Dynex TV; here some of the codes we currently have: 538, 720, 115, 834, 507, and 445. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
Phillip Chang
Aug 10, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 42" HDTV - pressed "Comp" button now cant get back to TV
Press the TV button on the remote. You are confusing the Comp button with the Input button which allows you to switch between input ports.
Dec 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex DX-L32-10A 32" LCD HDTV Logo
949 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
