Question about Maytag Dryers
The lint is not getting caught in the lint trap, the vent tube is full of lint, and the clothes are taking longer to dry. Is there a possible blokage inside the dryer?
  • 478 Answers
Yes, maytag has two screws located on front bottom. Take off front of dryer and vacuum out everywhere in the machine and the exhaust line. Check your belt as this is a good time to change it, if you have never done so, you may need to take a digital picture to aid in putting on new one; its a little tricky. Good luck!
Posted on Nov 07, 2010
Maytag Neptune Dryer Not Drying Well, Leaves Brown Marks on Clothing. Seems like there may be multiple problems. Suggestions?
Sounds to me like an air-flow problem. Poor air-flow means dryer gets hot and scorches clothes but there is nowhere for the wet air to go, so it doesn't dry well. Check for lint-clogged ducting from the back of the dryer to the outside (or at least check both ends of the duct). Also check for a collapsed or clogged flexible tube that goes from the dryer to the duct work.
An over-heated dryer could also have warped the (usually) plastic lint filter.
Jan 07, 2015 | Maytag Dryers
Tip
Clothes dryer taking to long to dry clothes
If your dryer is taking a much longer time to dry clothes here is a simple tip. Remove the vent tubing and more than likely it will be full of dense lint. Dryers made these days have a safety device that will shut off the heat if the temperature gets too hot inside the dryer. In most cases when the vent tube is blocked the dryer will not even heat up for you making you think your dryer has broke down. Before you go as ask questions about the operations why the heat does not work, inspect and clean if necessary. In most cases the dryer will work normally again for you. Oh yes another hint. The vent tube should be four feet or less in length with out no bends or elbow fittings with the exception of the connection directly to the dryer. Longer vent tubes will give you grief every year for they will need to be cleaned that often
on Apr 07, 2010 | Washing Machines
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Clothes are not drying as fast as before. Lint trap is not collecting ling.
venting issue. check vent tube for restriction. A quick way to know if it is external is disconnect vent tube run a load of clothes if they dry well then it is the tube, if it is the same then it is internal and the dryer will need to be disassembled and cleaned from the lint trap back. Good Luck Tim
Nov 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Okay-so far NO ONE -even at Sears-has been able to tell me what is wrong with my dryer-this is what happens-I can dry my clothes-but if they sit in there for more than 30 minutes after drying they become...
I would say it is the vent hose, you can buy the hose that has like a trap on the end, in other word you will not need to run it out through a wall. Since you indicated that there is a lot of wetting under the lint trap in the bottom of the dry...I would venture to guess that something is loose and not full connected to the back of the dry where you hook up the vent tube. all you have to do is take the front door/panel off and look at the tube running from the trap to the back of the dryer. Hope this helped tim
Aug 28, 2010 | GE DBXR463EDWW Electric Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
