Question about Music
I just play with my stereo chorus 212 (peavey) and all stop.do you tink is the fuse 250V
3 Suggested Answers
  • 5603 Answers
SOURCE: peavey classic chorus 212 buzzes, sguelches, squeals...
There MAY be a circuit trace on a board that is cracked OR a poor soldered connection. It is vibration sensitive as you have found. Changing a switch vibrates the unit.
Depending on what you have connected, this could even ba a bad input jack.
The unit needs to be serviced. You could open it and see if there is something obvious.
Posted on Jan 15, 2010
  • 11800 Answers
SOURCE: I have a Peavey Audition Chorus amp with two 6"
The chorus effect is basically an reverberance effect: the part of the output signal is put back at the input, creating a slightly off temp signal and thus the appearance of several voices from one.
This process is done entirely inside the unit with a switch. That switch does 2 things: it activates the processing circuit and in the same time switches the amplifier for the second speaker from a parallel processing to a separate one.
Since the second speaker shuts down when the chorus effect is activated it means that either the actual circuit that generates the chorus effect or the logic board that makes the switch of audio sources has failed.
The unit will have to be opened, the chorus and logic boards tested, the failed part identified and replaced - a job for a very well experienced repairman. In this sheet you will find a block diagram, it will help you with the diagnostic procedure
http://www.peavey.com/media/pdf/manuals/80300753.pdf
Posted on Aug 15, 2011
Blowing the main fuse.on my peavey 212 renown.can someone help me out.hate to scrape the thing.
This is a vacuum tube driven amp. First thing to do is remove all the tubes and see if the fuse burns out. If it does not then a tube is bad. Process of elimination to figure out what tube it is.
Jun 13, 2016 | Peavey Music
How do I run the Peavey - 212-6 cabinet at 8 ohms stereo?
After quite a bit of searching around, I stumbled across this cab and figured you usually can't go wrong with Peavey (for durability anyway) and coupled with 2 Celestion Green Backs for this price?! Had to give it a shot. Glad I did. Very versatile cab, can run 16 ohm stereo or 8 ohm mono, removable back so can run closed or open. Just what I needed. I run mostly open back, just my preference, but closed back sounds pretty decent, much more punchy.
Mar 26, 2016 | Peavey Music
Valveking 212 combo shows lamp lights but power tubes are not lighting no sound
no filament power then, filament fuse open..blown winding on transformer, regulator bad..You an ET with shop full of tools...then we can get to work...
Dec 31, 2013 | Peavey ValveKing 100w All Tube 212 Combo...
Fuse for Peavey JSX 212
did you want to know where it is???
Dec 22, 2013 | Peavey Music
Peavey xr600f
250V 8A SL(Slow-Blow)
Sep 29, 2013 | Music
Peavey renown 212
If no fuses blown you probably have an issue on your +15V and -15V power supply regulators, this can be tested by checking opamps supply voltage which should be +15V at pin-8 and -15V at pin-4, let me know further.
Jun 22, 2013 | Peavey Music
Peavey classic chorus 212 buzzes, sguelches, squeals...
Jan 13, 2010 | Peavey Jsx Mini Colossal Guitar Amplifier
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
