Monitor is taking too long to warm up and start working; up to 1 hours at times
  • 91 Answers
DEAR SIR,
IF U HEAR BEEP SOUND WIYHIN FEW SECONDS OF SWITCING ON THE CPU , THAT MEANS MOTHER BOARD IS SENDING SYNC FOR MONTITOR . .. IF BEEP IS COMING LATE & MOTHERBOARD IS IVING SIGNAL BY LATE ENTER THE BIOS MODE & DISABLE ALL DEVICES WHICH ARE NOT INSTALLED, LIKE FDD, ETC SINCE BOARDS SEARCHES FOR COMPONENTS , SECOND THING ENABLE FAST BOOST , IT WIL SKIP ALL MOTHER BOARD TESTS
REGARDS
RAJ
NPCONLINE
Posted on Nov 06, 2010
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Dear sir; I have LCD 15'' sumsung monitor, its problem is that the display took time after cpu on. it takes long time about one to two hours to display. However after display there is no ploblem.
Only thing I can think of is that the monitor is dying and takes a long time to warm up. One trick might be to always leave it on (so it stays warm) or replace the monitor and your problem will probably go away.
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 24, 2010 | Computers & Internet
1999 Toyota RAV4 losing power not stalling it is stumbling & new fuel filter & fuel pressure stays at 46psi
As a quick test,fill-up the tank and do not top off.
Monitor the stalling problem.
If you're starting OK until BELOW 1/3 of the tank then it's a weak/failing fuel pump
Are you topping off the tank (MAX OUT) of while you're filling?
The emission control system can soak with gasoline if you over fill.
Locate the emission line that lead to the charcoal canister and let it air out under direct sunlight.
After 1-2 hours,reconnect the line and use starting fluid to start the car.
After 10 minutes of warm up time,then take it for a short test drive.
Nov 11, 2009 | 1999 Toyota RAV4
LCD Monitor takes time to display HANNS.G Model
there is leak capacitors problem inside of your monitor they need to be replace so that your monitor work normaly
May 22, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor not powering up
I'm not too sure about dell pc's.But if you think a fuse might be inside there,I'd try to do a search online for how to change that and go from there.However,I'm not really understanding the warm up thing.Is it an LCD screen?
Feb 12, 2008 | Gateway FPD2275W LCD Monitor
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
Monitor took half an hour to warm up, now won't start.
doubtful this is a driver issue warm up is not needed for any monitor. this is a power board issue internal to the monitor capacitors or some issue on the main power board. let me kow what you will do. good luck.
Nov 18, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor takes 1/2 hour to warm up
You need to check the fly back of your monitor maybe experience over heat. It is possible need for replacement but not the whole monitor only the fly back.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
130 people viewed this question
Alun Cox
David Payne
David Payne
