Powering on my tv
I have this real strange problem.When I try to power on my 37" magnavox lcd it will not come on right away,what happens is this:
I press the power button the green light comes on then it starts flashing,
then the light becomes bright,it does that for about a minute then it goes off.I power the tv on again,the green light flashes for about 15 seconds then it goes of,I power the tv on again for the third time this time the tv comes on,please help with this problem.thanks
model # 37mf331d/37
  • smmmobil Jun 23, 2008
    what can I say fixya guys, your'r the best.I changed the board and the tv is fixed.
  • 38 Answers
Dear smmmobil,
The problem lies with the SMPS (switch mode power supply ) of your TV. The smps board needs to be replaced.
ramesh22
Posted on Jun 15, 2008
Magnavox 47MF437B/37 works fine until turned off. The red standby light comes on but the TV will not turn back on again. I have unpluggged the TV then plugged it back in again. Sometimes the the TV will...
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the solution
Jun 12, 2011 | Toymax Magnavox 47MF437B 47 in. LCD TV
I have a 37 in HD Magnavox lcd television - 1-1/2 years old - It takes several tries to turn it on. Is this something I can fix myself like from using an electronic cleaner? (I live rurally so I have...
This is the power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Or take the power supply board apart's,check for those capacitors parts are dying,alway bulges up it tops or puffing up on it tops.U have tools and kmow basic electronic and soldering.Replaced these dying capacitors,tv should come on right away.Use a cooling fan,turn it on high,put close to it.All the dust and particles.Will blown out.
Aug 08, 2010 | Philips Magnavox 42MF521D/37 Television
Magnavox 37MF231d/37 LCD TV cycling thru colors
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 06, 2017 | Toymax Magnavox 37MF231D 37 in. LCD TV
37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 37MF331D 37 in. LCD TV tv will not come on, power light blinks. I tried disconnecting power cord and hold power button to discharge, still will not come on and as soon as I apply power again the...
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
Sep 12, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
37mf231d power light flashes on and off will turn on after you keep trying
set the time on your tv and turn off the timer, sleep and wake funtions.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
Not powering up right away
This is a big problem with these tv's. Magnavox built them with undersized capacitors, and they blow. You have to open the back, remove the power supply and replace the capacitors numbered 2074 and 2081. This sounds like a real tech job, but read my other solutions, and you will see it is not so hard. Good luck.
May 28, 2008 | Philips 37MF321D 37 in. LCD Television
Televison & Video Logo
354 people viewed this question
Top Televison & Video Experts
