Question about Miele Washing Machines
Miele 418 Washing Machine. Gets to end of cycle but does not do the final spin. Pump out motor just runs (for some extended time) and empties water but no spin ?? Any ideas ?
    Problem Solver:
  • 12 Answers
Check the motor brush's.
Posted on Jun 15, 2008
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
I have an LG front loader - model WD - 804 90TP and the machine is working but it gets down to 6 mins to run the spin cycle and then goes up to 14 mins and then back down again and carries on in that cycle...
You need to check the inlet valve for good flow of the water as a SLOW water pressure can increase the timing for rinse and spin.
Similarily the DRAIN pump/valve must be checked as if this is clogged then the drain flow will be LOW and the timing will extend for full drain. Remove and clean the drain pump and it can be the reason that the clothes are still wet.
Finally check on the controller for the proper timing of the cycle.
Tips on Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | LG Washing Machines
I have a Whrilpool washer model LHW0050PQ 2. It will work perfectly then will not spin. At the end of the cycle the done light just flashes. If I choose to just choose spin cycle you will hear it go...
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
Locate and clean the filter. There is a round unscrewable filter cover on the front of the machine at the bottom right, behind a small door. Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter its self and get your floor wet, so take a look for this before you remove the filter and get soaked.
If this IS the case, you need to call the repair guy out again and when he gets there, kick him all round the house until he gives you a refund foe his last 2 visits!
Jul 11, 2011 | Whirlpool Washing Machines
F&P GW712 washing machine, the machine washes and when it gets to the spin part it wont spin, it tries to and then a continuous beeping sound and too lights long wash & short wash comes on until...
hello what might be happening when it's going through the cycle and come to the spin part there may be not enough water empting out from the pump causeing it not to spin also there may be a fault with the module board the control the motor speed also brushes on the motor can cause spin problems hope it
regards
shaun
May 01, 2011 | Washing Machines
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
147 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
