Question about Eton E100 SW/FM/AM Radio
Satellite radio doesn't work
I bought a E! satellite radio and after passing through security at an airpot the memories got ruined. Can this be repaired, and how?
Where can I send this, and how long does it take to fix?
Sandra
  • sandracerrut Jun 15, 2008
    I put in ht frecuency and it skips from the top to the bottom to the page. When I dial in a frequency it doesn't come out. No I can not use it.
  • sandracerrut Jun 16, 2008
    i cna;t get a hold of a repair man for an Eaton E1
  • 487 Answers
The problem is that when it went through the Xray it screwed up the computer components which are in the radio. Normally at a service center they can re-program the radio and it should work just fine after that.
Please follow this LINK for all Eton repair centers( non-warranty)
How long it will take I do not know but they stand behind their product.
Posted on Jun 16, 2008
  • eric bosman
    eric bosman Jun 16, 2008
    trying to get compensated by the airport is an option but that will take an awefull long time
  • eric bosman
    YOU CAN TRY this link IF YOU TRY FOR A WARRANY REPAIR
    Genius:
  • 1,036 Answers
Hi there!
This device has been damaged by the Airport security system.
Therefore there should be some recompense from them.
You were told you MUST use their system - and did.
This damaged your equipment. Therefore they are at fault for damaging your property.
The only exception is that if you were warned this may be the case, you could have had the opportunity to choose a search rather than Xray.
Contact the Airports complaint department. You will not be the first to suffer such loss, and a limited compensation may be paid out to you.
I hope this will help you in some way.
Richie.
    Sergeant:
  • 243 Answers
Well its a short wave radio. and it will most like need a repair. But seeing the cost of this unit if its out of the warranty period. The unit will just be easier to replace as its only a 80 dollar unit.
  • 13,433 Answers
Heres a list of services listed on fixya
http://www.fixya.com/Services.aspx?prdid=440173&zip=&x=16&y=19
Posted on Jun 15, 2008
Xact XTR2 will not turn on
Its likely that the unit itself is bad. Do you have another dock or boombox to plug it in and trouble shoot with? If it doesn't power up in multiple sources it could be dead. Either way, TSS Radio can help:
tss-radio.com
Jun 17, 2012 | Sirius Satellite Radio XACT XTR2 Satellite...
I just bought a 2007 Dodge 3500 Laramie and signed up for Sirius radio. I gave them the 12 diget number that came up on the radio screen (channel 184) and when they tried three times to activate it nothing...
I bought a used 2008 Ram 1500 SLT Sport; satellite would stay stuck on channel 184 with no sound, etc.
Solution: Disconnect negative wire from vehicle battery; wait 1-hour then reconnect. This clears satellite radio cache (a.k.a. hard reset).
Turn on satellite radion; Call Sirius support to send activation signal. Wait on phone with tech support; may take them 2 - 3 tries to get signal to take on radio.
Aug 21, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
How to decode radio for vauxhall combo 02 reg and have no code
vauxhall charge £29.99 for security pass for your car each radio has a different code so there the best bet m8 they will give you the pass and put the code in for you
thanks jeza
Mar 03, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
Bought a motor home with a vr185 jenson radio installed. have no instructions on using it.
you can find the manual here
http://caraudio.manualsonline.com/regman/exit/ct?url=aHR0cDovL3d3dy5hc2FlbGVjdHJvbmljcy5jb20vdGVjaHBkZi9WUjE4NSBPd25lcnMgTWFudWFsIDExLTYtMDYucGRm&target=productDoc&idDeviceType=2402&idMfg=14325&idProduct=215757
Feb 04, 2010 | Sirius Satellite Radio Sirius Starmate ST1...
Antenna not found sirius satellite radio
You may have a defective satellite antenna or cable
Nov 09, 2009 | Sirius Satellite Radio Receiver
XM Direct 2
On the adapter cable if there is a separate cable for power connect the positive directly to battery power as opposed to ignition. The memory resides on the xmdirect2 module not on the head unit.
Oct 04, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Memory
Hi there!
This is a problem caused by the Airport's securuty systems.
They have damaged your equipment. If you were not warned of the risk and given a chance to avoid being scanned, then you should be entitled to some compensation for the damage.
Contact the airport customewr services. They should be able to advise you from there.
I hope you get some compensation for it.
Jun 15, 2008 | Eton E100 SW/FM/AM Radio
SIRIUS S50 radio car kit won't turn on
It may be that the dock isn't working, I would return it for a new one to the place that you bought it from to make sure that you have a dock that works.
Apr 18, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Memory stills says full
Reset it...this should be an option. If not then call that 800# or I can look into this more for you. S-50 is
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=601930
Feb 11, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Eton E100 SW/FM/AM Radio Logo
91 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
RobertFonner
RobertFonner
David Burbee
David Burbee
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
