Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I need to remove the doors to fit into a room - how do i do that?
  • Whirlpool Master
  • 43,501 Answers
Hi.
At the very bottom outside corners of the doors are a couple of bolts that hold the hinge...remove the bolts and then the door will just drop down a bit and come off of the hinge on the top....
If the hinge at the top also needs to come off, remove the plastic cover by prying under it with a screw driver.... then take out the three screws that hold the top hinge....
It is often better to have someone just hang on to the door with it flipped around to the side rather then removing all of the wires and hoses....they are very complicated to remove and the door will swing all the way out and around once the hinges are removed...
heatman101
Posted on Nov 07, 2010
I need help to change rubber tracks on my KUBOTA digger KX 021 ...PLEASE ?
you will have to open the small access door on the side of the track carriage and remove the fitting on the tension cylinder. this will allow the cylinder to back off and give you room to lever the track into place. once the track is in place put the fitting back in and pump it full of grease until you have proper tension.
Oct 25, 2016 | Kubota Garden
2003 pt with turbo what's the best way to change pressure hose on the power steering from the pump to the rack.?
There is no "best way" however, removing the driver side headlight will give ample room to access the fitting on the pump. ( 16mm bolt head ). Raising the vehicle in the air will give room to access the fitting on the steering rack. Patience and a couple shots of JD will also help
Jul 10, 2015 | Cars & Trucks
Can I disassemble the loveseat to make it fit through the door.
I think you can disassemble tis, but you never will be able to put it together again. Ask some strong guys to help you to bring it in the room you want it. Sometimes it only needs to be put on its side and make a turn. use some cloth to shield the exterior. Must fit to almost all normal doors.
Jun 10, 2014 | Ashley M Ashley Furniture Wesley - Sienna...
Viking professional defrost cycles
Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
Jun 08, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Cant fit it through the door to move to another room.
Only 3 choices:
1 - leave it in place
2 - Take it partially apart so it will fit through the door
3 - Widen the door frame.
Since the treadmill got into the room, it should be able to get out. Most likely #2 is the option for you.
Dec 07, 2010 | Nordic Track NordicTrack A2550 PRO...
How to replace mirror on 2008 ford explorer
Remove front door inside handle bezel. It should snap off waway from the door. Remove the screws behind bezel. Remove the screws on the bottom of the main door trim panel. DO NOT PULL OUTWARD ON THE DOOR PANEL OR IT WILL BRAKE!! Remove the door panel by lifting the pael upward. at this point you ay have enough room to access the 3 nuts behind the mirror and te mirror electrical connector. If there is not enough room then you will have to disconect the electrical connectors and the door handle linkage on the door panel. if there is eonough room for you then disconect the mirror electrical connector first then remove the 3 nuts behind the miror. the mirror should just pull strait away from the door. Reverse this proceadure to install new mirror. This is the same for left or right side.
Jun 18, 2010 | 2008 Ford Explorer
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
