Question about Garmin nuvi 250W GPS Receiver
I have a Garmin 250 w that is locked with a pin # or a security location. Is there anyway to unlock it? Thanks
  • Garmin Master
  • 589 Answers
You have to go with 50 meters of the SECURITY location for the unit to unlock automatically, your security location is the place you set up your gps on the first day. you could of been at home or work
once unlocked you must reset the pin number
or you would have to send your unit back to Garmin with the proper ownership receipt. All garmins are registered to unlock map data.
Posted on Nov 06, 2010
I just brought a garmin 250 from a bootsale but it has a pin lock anyway i can get a code?
Unless the vendor supplied it, you cannot operate a locked Garmin and you cannot bypass the code.
The following is cut and pasted from my existing FixYa Tip and deals with your precise problem:-
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of first purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
You may read advice elsewhere advising you to use a secret menu to erase all user data. This is done by starting with the nuvi switched off and then pressing and holding the bottom right corner of the screen and then, whilst still pressing the bottom corner, turning the unit on. Please note that although this erases all previous user data, it does not bypass Garmin Lock. There is NO bypass for Garmin Lock except by taking the unit to the owner's security location; it would be a useless theft deterrent otherwise.
Jul 19, 2011 | Garmin nuvi 250W GPS Receiver
I just brought a second hand garmin 250 but havnt got a pin code
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Jul 19, 2011 | Garmin nuvi 250 GPS Receiver
Lock
Garmin lock is a theft-deterrent system that locks your Nuvi. each time you turn on the Nuvi, enter the pin or drive to the security location to unlock.
Touch tools>settings>security
touch the button below Garmin lock
Enter a 4 digit pin and drive to security location
Note if you forget your PIN and your security location, you must send your Nuvi to Garmin to unlock it. You must also send a valid product registration or proof of purchase.
Oct 16, 2010 | Garmin nuvi 200W GPS Receiver
Pin code unlock
You have Garmin Lock activated and there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it).
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
May 31, 2010 | Garmin nuvi 200W GPS Receiver
I forgot my pin numbrer for garmin 205w. is there anyway to bypass security code
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Oct 15, 2009 | Garmin nuvi 205 GPS Receiver
Can't remember pin for garmin nuvi 660 fm , it also won't unlock at secure location.
Either remember the PIN
OR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note Garmin will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
Oct 02, 2009 | Garmin StreetPilot i3 GPS Receiver
I lock my phone and forget my password for my garmin nuvi
Jul 14, 2009 | Garmin nuvi 250 GPS Receiver
Garmin Nuvi PIN reset?
I think the true purpose of the pin is for another income stream to garmin they want $110 to unlock it. If not then why not just register a pin when you register for the warranty then just use your MY GARMIN to get it when you need it???
Jan 15, 2009 | Garmin StreetPilot c340 GPS Receiver
Unlock code for my garmin nuvi 350
Jan 02, 2009 | Garmin Nuvi 350 Car GPS Receiver
UNLOCK GARMIN
I have de solution:
*pick a torx 3 tool
*release de equipment
*put on 22 awg copper cable in the main chip on upper right pin and touch softly the + pole of a 3V batery.
tested in a garmin nuvi 780
Nov 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
179 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
