Question about Sharp Televison & Video
I would like to know how can I connect my sharp t.v. To my DVD for surround sound!
  • 28 Answers
You kan try this. IF your dvd and tv have digital input. This is a sqared small cable. If your applience do not have this feautures. Do it easy with the scart cable in AV 1 on tv, that holds red and white cable, with a regular jack output on the other side to the dvd. Or if your dvd has input for the red and white, you can use that in both ends.
Posted on Nov 06, 2010
My surround sound won't work now when I play the dvd player
Could be many things - I know, bad answer. There is no simple answer or fix.
Without more info one can only speculate.
Please determine and answer as many or all of the following so that we can help.
1) What is the make and model number of the Surround sound unit?
2) What is the make and model of the DVD player?
3) How is the DVD player connected to the Surround sound unit?
3a) Is it connected via an HDMI cable?
3b) Does the DVD player have regular stereo connections that you are using (we call these analog audio connectors)?
3c) does the DVD player have digital audio outputs that are connected to the Surround sound receiver?
4) Did the DVD player EVER make sound?
4a) if yes - what changed?
4b) if yes - does this happen with different discs?
Now some general points.
I'll assume that the other sources do work and play sound through all speakers when they are supposed to play sound through all speakers.
Then - I'll assume that without changing anything else you select the DVD player input that used to make sound but doesn't now.
Problem could be the encoding option that you have selected when you play the disc.
Many DVD's and Bluray's have audio options that you can select from the disc's main menu.
Dolby digital is the most common - also known as AC3.
Some discs have another digital audio track called DTS.
Not all surround receivers can decode all formats.
Even if your surround receiver claims to be able to decode AC3 and DTS, they will not if you don't connect the correct cable to the receiver and usually map the input to the correct digital audio connection that you are using OR if your DVD player is not capable of outputting all formats.
There are many different ways to connect the gear and many different ways one can configure correctly or not; all contributing to whether you get sound or not.
So in the above example - by selecting DTS, you do not get any sound - then try another audio track option. Basic stereo usually works (also know as PCM - which is audio like a CD).
OR maybe you never properly configured the audio properties of the DVD player.
Go into the DVD's menu or set up options and see what you find but make sure you know how the DVD is connected to your surround receiver!
As you can see - there is no simple answer without a lengthy Q and A exchange first.
May 26, 2014 | Yamaha Audio Players & Recorders
How to hook up sharp dolby surround pro-logic model- HTDP3000 to my RCA tv I need to know exactly how to connect the wires from sharp surround sound to my RCA high definition tv
The source of your program will determine how you hook things up, and if you want to (if it's possible) route the video through the Sharp as well. Some systems have video switching, so you can run all sources through the system, and have a single video cable running to the TV.
If you are using a DVD player, typical Pro-Logic requires a red/white RCA cable from the DVD player to the amplifier unit. The video cable, either a 4-pin S-Video or a yellow composite cable, will run to the amplifier unit for switching purposes, or ditect to an input on the TV.
You can also run red/white RCAs fron the HDTV to an input on the Sharp. You likely have to set the TVs audio output to "fixed" or "external", which will disable the TVs speakers, while putting out sound to the Sharp.
Jan 06, 2011 | Sharp HT-DP3000 System
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
I'm not getting YHT 391 surround sound during TV viewing. Surround sound is available for DVD, Tuner. Connection via HDMI Cable from the YHT 391 out HDMI to the HDMI #6 on a HDTV 1080p Sharp.
I havent received my system yet,but while reading the manul it says the hdmi cable only transmits the picture(i know i know hdmi supposes to transfer both)you suppose to hook up an dital or coaxile cable for the sound
Sep 13, 2009 | Yamaha YHT-390 Theater System
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Adding Surround Sound to Sharp 32R-S50 32" TV
if the tv has outputs at the back for surround speakers then you can connect it to them..else pass the audio of your TV thru a home theatre surround receiver
Mar 05, 2008 | Sharp 32R-S50 32" TV
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
