Question about RCA F32650 32" TV
My tv wont come on..i plug it in and it just humms no picture
  • 4 more comments
  • jamel mclaurin
    jamel mclaurin Nov 06, 2010
    my tv wont come on..i plug it in and it just humms no picture
  • jamel mclaurin
    do i have to get a new tv or can it be repaired
  • jamel mclaurin
    so do i need to get a new tv.. or can it be fixed..
  • jamel mclaurin
    i hear what ur saying..i,m asking do i need a new tv
  • jamel mclaurin
    thank u
  • jamel mclaurin
    thanks eagle338
  • 4,889 Answers
The humming sound you are hearing is due to a failed High Voltage transformer, also known as Fly Back Transformer(FBT). You are gonna have to get it replaced by a qualified tv tech. You do not want to mess with 15000V trust me!
Posted on Nov 06, 2010
  • 2 more comments
  • eagle338
    eagle338 Nov 06, 2010
    Are you kidding me? I have seen this a thousand times in my 4 years as a repair tech. It is the only thing that can cause this humming noise and the CRT won't turn on due to no high voltage. I gave it to you straight without beating around the bush. If you don't like it feel free to keep getting the same diagnosis from all the techs.
  • eagle338
    It can be fixed. The flyback is gonna cost you more than 50-75$. The tech would charge you about the same amount to replace it. Its not very tough repair the only tricky part being discharging the high voltage
  • eagle338
    In my last post I meant to say the flyback is NOT gonna cost you more than 50-75$.
  • eagle338
    You are welcome. Thank your for using Fixya!
Receiver humming
Have you tried unplugging the Receiver from the power outlet and plugging it back in? Is your Receiver a service providers set top box DVR? It sounds like you may be hearing the Hard disk drive spinning on and off. But that's all I can tell from the description. Hope this helps.
Oct 13, 2013 | Directv Televison & Video
My we will remote wont connect to the tv
my wii wont come up on my tv when i plug in the scart lead no picture comes up,ive tried to go through the source channel system but still no picture,i have sky hd and broadband in my home downstairs on the tv i,m trying it on is it the router,will i try it on the bedroom tv
Aug 23, 2012 | Nintendo Wii Console
Tv has a loud humm and no picture
Hi:
You must replace the color wheel this is the noise you are hearing, sounds like a airplane reversing engine. Loud wining sound. This is a indication of the bearing on the color wheel gone bad. You can find videos on youtube on how to replace a color yourself and save some money..
Jun 12, 2010 | Samsung Televison & Video
2000 chevy express 1500 van having starting issues
Start with fuel system. Listen for fuel pump humm at fuel tank No humm check wiring to pump for power. Then check for spark at plugs and wires. Remove wire from coil and hold near engine and see arch when you crank. No arch. Replace ignition Modular inside distributor cap or cap or rotor
Feb 04, 2010 | 2000 Chevrolet Express Cargo
Audio humm on VIZIO VW32LHDT30A
You have a bad ground through the cable box or cable system. This causes AC to leak into the TV showing up as bars that roll from bottom to top and sometimes audible as well. Have the cable company replace the cable box and/or check out for proper grounding outside at the demarcation point.
Mar 23, 2009 | Vizio VW32L 32 in. LCD HDTV
Cold weather does not start
Need to listen for fuel pump humm for proper operation. Shoud humm for about 3 seconds with key turned in the on position. Humm will sound from gas tank where the pump is located. If it does not humm. possible Faulty Fuel pump relay or pump. It will need ferther diagnosis.
Jan 09, 2009 | 1998 Chevrolet Cavalier
Loud humm. I have to keep the volume down when watching the TV.
A humm may be caused by a cable TV grounding problem called a "ground loop." Basically, the grounding for the Cable TV line and the power outlet for the TV are at unequal levels. I had this same humm with both the internal TV speakers and with external speakers (headphones, etc.). The 2 solutions are (1) install a Ground Loop Isolator at the TV, or (2) call the cable company to troubleshoot the problem. I figured the time I saved dealing with the cable company was worth the $50 for the part. I installed the Jensen VRD-1FF which has worked perfectly! Ordered from eBay and saved about $12 over the Jensen Electronics web site price. Hope this helps.
Dec 05, 2008 | Bose Lifestyle 28 System
Misubishi rear projection tv (15 years old)
Do the diagnosis test read at www.ctechnicians.com
Nov 26, 2007 | Televison & Video
Rear Projection... Hitachi tv
humm.. could be a crt or a high voltage problem..flyback transformer or high voltage splitter... have a tech check it out for you.
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F32650 32" TV Logo
321 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
