Question about Car Audio & Video
I have an alpine cda9831 unit with 10" subs. I have an alpine v power m500 independently running them. The subs will randomly cut off and on and the wires to the head unit have been checked for loose connections. The amp was purchased 1 day ago. Please help if any suggestions.
    Genius:
  • 1,066 Answers
So you have already ensured that there are no crossed/loose wire strands.
you are running 2 subs off a single alpine mono amp.
if subs are 4 ohms apiece, you should be fine. if you have 2 ohm subs, or you have dual voice coil subs and you are running all the voice coils parallel, then there is your problem. you can have a maximum of a 2 ohm (2x4 ohm speakers= 2 ohms.) load with that amp.
ensure that the subs are 4 ohms apiece, and that you are not using dual voice coils. if the subs have 2 inputs (dual voice coils) then only use 1 input apiece.
if this is already taken care of, then your amp is defective.
Posted on Nov 06, 2010
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be...
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Mar 11, 2011 | Alpine MRP-M500 Car Audio Amplifier
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
I have an Alpine M500 mono amp that works great, until you turn up the volume. I can adjust the bass down at the head unit, but at higher bass the amp shuts off. And then comes back on after a couple...
I don't think either, I believe your running theamp load too low with too low an ohm speakers and this cases the amp to produce more power but not stable and it overheats and the thermal protection cuts the amp off when the temp gets too hot to prevent damage.. Make sure your speakers depending on how they are wired do not exceed the amps load rating
Oct 26, 2009 | Alpine MRD-M500 Car Audio Amplifier
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Alpine MRD-M500 Amplifier
That is a code to inform you of an issue, and to help direct you to a particular area of concern
HOT & E-1 = both for heat issue
E-2 = for a voltage issue
E-3 = for a current issue.
While yours is a current issue, that reflects a problem with your input or output signal pairs. You should disconnect the subs at the amp, then operate the unit as normal to see if the code reappears. This is the start of your process of elimination, where as you will be able to determine the general location of the issue, weather it is before - internal - after the amp, hence If after the subs were disconnected, the code did not return then it would be obvious that you should focus on the subs and their signal pairs. troubleshooting in small increments until the issue is discovered.
Hope this helps...Good luck
Aduz
Mar 27, 2009 | Alpine MRD-M500 Car Audio Amplifier
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Audio & Video
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
