Question about Garden
Hi, got a fault with my HSA6400 Premium alarm panel that wont clear, the amber LED indication is illuminated the fault is displayed as ?panel telephone line fail?. The phone line into the panel has been proven sound as it works when plugged into a standard telephone. This is the only fault displayed within the fault log, but when attempting to accept /reset the fault it will not clear. The fault is also restricting arming the alarm; it will only arm when in force alarm mode. Any advice will be greatly received, many thanks Andy..
SOURCE: 2001 Subaru Outback security code won't stop flashing !
im a service manager at a Subaru dealer. The security system is in valet mode. Open the drivers door, with the drivers door open hold the small unlock button on the remote and keep holding it until the light stops flashing.
Posted on Dec 06, 2008
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
SOURCE: uniden vs1100xr car alarm will
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Posted on Apr 18, 2009
SOURCE: danby DDW396W-2
I have had a similar problem numerous times, a couple of which required manoeuvreing it into a place I could work on it, and a laborious removal of the covers. Each time, up until this current incident, the solution that worked, at least temporarily, was quite simple. The recurrent problem was at least consistent: every 6-8 months I would find that the pump would work but the spray arm was not moving. The solutions always seemed to be something different: once all I needed to do was to prime the pump, other times it seemed like calcium and lime build-up was clogging up the parts so a little C.L.R. got me on my way.
This most current incident was more baffling, as my standard solutions did not work. However, I think I finally got to the root of the problem.
Look inside the dish compartment, to the right, near the top. There are two little nubby holes. Their function is to allow air to enter/exit either the spray arm pump tubing or the water filling tubing. Remove the one zillion screws from the cover to access the innards. Pull off the tubing and unscrew the washer (it will be tight due to the sealant on it). Upon inspection, I found that the air hole for the spray arm pump was clogged with food residue. A tiny screwdriver will clear things out nicely - you should be able to see through it. If you clear it out a little but, but still can't see through it, then I presume you're just going to have the same problem back again.
It is important that this be clear so that the water can displace the air while filling is occurring and allow for good suction. Actually, it looked like a manufacturing flaw - there was still some residual plastic from the original molding on the inside, and food was getting caught on it.
Good luck.
Posted on May 26, 2009
krb55
  • 604 Answers
SOURCE: hi i have a bosh
I believe that this system utilizes your power line as it signal path (for arming etc). the problem is your are getting voltage spikes during the night (most likley all the time). the only way to eliminate these spikes is to use a power line conditioner, however if you do you may not be able to arm your system with the remote control (as the power conditioner may isoltate your device from the line, (needed for communications). if you can find a line conditioner that ony filters voltage spikes and not an isolation type unit, your remotes may still work. You can arm the unit at the control box however. good luck
Posted on Mar 22, 2011
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
What is the esp indicator for on a car amplifier
I found this
when illuminated (yellow) indicates ESP®
functionality and
is used to diagnose ESP®
features. The LED flash characteristics will assists in diagnosing the type of fault (see Appendix).
NOTE: The LED on top of the amplifier may also illuminate and flash with the ESP®
LED
indicator, if this option has been enabled by your installer (requires Bitwriter®
12. ESP®
Port - connection port for Bitwriter®
or ESP2 security system.
I googled it but all i came up was people with a flashing light and mine was solid so i figured id askk!!!! but i think i figured it out i took the sub out and pulled the box terminals and tightened them cause i noticed they were loose and viola it worked.
To further confuse I found this, but don't believe it.
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Aug 24, 2015 | Cars & Trucks
Aeg electrolux dryer
Displaying the alarm code
The alarm code is displayed by a repeated sequence of flashing of the ANTI-CREASE/END OF CYCLE LED (0.4 seconds on, 0.4 seconds off, with a pause of 2.5 seconds between sequences). The buzzer emits a series of ,bips" in synchronization with the flashing of the LED.
  • ANTI-CREASE/END OF CYCLE LED: indicates the first number of the a alarm code
  • START/PAUSE LED: indicates the second number of the alarm code
Now you must count how many times the LED lit up and we will know the fault code.
24383347-wycorcio5u0xxoh2plbhrodj-5-0.jpg Dado
May 10, 2014 | AEG Dryers
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Amber light on front of laptop flashes even with the power off
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Amber light on front of laptop flashes.
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
