Question about Flip Video Flip Ultra Camcorder
The small retangle, "ON" push button is lose, it
Hi,I have a sony dsc h9.. The shutter button fell off..i have the spring and the chrome button ..and i cant aee inside the camera as the base of the button is still in the camera..it also has a upright...
You can CAREFULLY glue it but, if you get any glue on anything around it, the camera will be inoperable. You can open the camera and replace the spring and button or take it to a camera shop to have it replaced. It is small tedious work.
Dec 12, 2012 | Cameras
Magnavox DVD eject button fell in TV
Take a close look where the plastic button was--it if there would engage a tiny round black rubber like button---using a pencil eraser see if you can gently push the button.
Jun 13, 2012 | Philips Magnavox 20MC4204 20 in. TV/DVD...
Fujifilm j38 lens is stuck in the camera
You forgot to pull out after the lens was pushed in on the side. That mistake makes it very expensive to fix. If you buy the same parts camera with a bad lcd on ebay. You can have your good lcd replaced on the ebay parts camera. Replacing lcd is an easier job.
Mar 30, 2012 | FUJIFILM Cameras
I have a Crosley CR248 CD Recorder and mistakenly put a blank DVD in the CD recorder and it will not eject. The unit is "locked" in "CD loading " mode and will not allow any other...
look for a small hole near the front of the cd drawer, use a pen to push the small button inside, and the disk should come out. some cd recorders don't have the button, but they are inside, you need to open the case to get at it and the push it to eject the cd/dvd one other thing you might try, is to unplug the unit from the wall (power) and then plug it back in, when it first powers up, push the eject button and it may come out then
Mar 20, 2011 | Audio Players & Recorders
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Grinder fell. Black "button" inside broke off.
Use just about any 2-part epoxy, clean parts with rubbing alcohol first to remove coffee oil and get a good bond.
Nov 08, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Seat recline buttons stuck
I would suggest that you return this for a repair to your retailer, if this is in warranty (2 years).
If not, you can dismember the white (retangle) buttons quite easily to enable the release of the seat frame,. On each button there is a small clip either side that you have to push in together. Inside each button is a spring, just make sure that you keep the spring for when you have put it back together. It does sound like the spring has just become dislodged.
I hope this helps.
Aug 24, 2009 | Bugaboo Frog - Black Stroller
The inside rear view mirror fell off I need to re=attach it
The button is locked into the mirror shoe by a flat spring. Find the notch at the bottom of the shoe and insert a small flat screwdriver to push the spring away from the button. Some force may be required.
Jul 18, 2009 | 1995 Mercury Mystique
Flip Video Flip Ultra Camcorder Logo
14 people viewed this question
Top Flip Video Video Cameras Experts
Tom Chichester
ray gallant
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
