How do I remove the screen protector on my Toshiba 57H84 rear projection TV to clean inside of it?
  • 150 Answers
SOURCE: TV Projection filter screen
I would not use any kind of chemicals on the screens, I definitely would not use any liquids on anything besides the screen protector, the inside screen is a Fresnel lens and will wick up moisture, the one with the vertical grooves is the Lenticular and either one will leave a mark, if you have to use liqud, I would try distilled water, but no guarrantees you will get it clean. I usually end up replacing the screens. Looking at your post you said filter, do you mean an air filter? I dont think these sets us an air filter, if it was just dust a t-shirt or microfiber towel usually work, the towel being my choice.
Posted on Jul 08, 2007
  • 1694 Answers
SOURCE: screen removal
1) Remove lower,front speaker grill
2) Remove screws along bottom edge of screen frame
3) Lift screen assembly off cabinet
4) Lay assembly face down
5) Remove just enough frame screws to get back in position--
    Don't force it----
6) Reassemble.........T.
Posted on Oct 28, 2007
SOURCE: Cleaning tv screen
need to know how to clean a hitachi rear projection screen tv
Posted on Apr 05, 2008
SOURCE: Removing a screen protector from a Hitachi 50UX58B Projection color TV
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).ea84b4b.jpg
Once this strip is removed, you should be able to see a gap (~2mm) between the top of the protector and the frame. Pull the middle of the protector toward you (you may need to hook it with something like a chrochet hook to get it out to where you can get a finger on it). Pull out one side of the protector, then work it loose fromt he bottom. (If it is stubborn, you may have to loosen the bottom frame. Take of the speaker grill, then unscrew the screw on the bottom of the surround for the control panel and pop the surround out. Then there are 3 screws that hold the cabinet frame {might me different for the 58B} and beneath that, 3 screws that hold the bottom of the inside frame. Once those are removed, you should be able to flex the inside frame enough to loosen the protector.)
Installation is the reverse. There are two grooves (at least on my set), and the protector goes in the rear groove(!) (same as the screen itself - first time I tried to put it in the unused groove closer to the front of the screen, and that iddn't work). The black plastic retainer strip goes in the front groove.
Posted on Jun 23, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
I have a 57H84 toshiba I bought new in 2004 I have lines from top to bottom approx 1 in apart.I have been told that is the bulbs that need to be cleaned .Can you tell me how to get in to the bulbs and...
57h84 IS A REAR PROJECTION SET WITH 3 picture tubes.
you got lines in picture top to bottom on the screen running left to right?
They go away after a while?
Apr 26, 2012 | Toshiba Televison & Video
My toshiba 57 inch rear projection tv every once in awhile makes a loud pop similar to a spark noise and the screen either goes black or flickers. do you have any suggestions what is causing this??
THis could be one of the CRTs (Color Tubes) is bad or the high voltage is leaking somewhere.
Toshiba projection TVs have history of yoke problems.
My guess is one of the CRTs is arcing inside. This TV has 3 CRTs red, green and blue. Replacing a CRT is not easy or cheap to buy if you can find it. If you like this try calling a TV technician to track down the high voltage arcing. DO NOT TRY TO DO THIS BY YOURSELF.
Best of luck my friend.
AAA TV SERVICE
Jun 12, 2011 | Toshiba 57H84 57" Rear Projection...
How to remove subtitles from sony bravia tv screen
You can download the user manual here.
http://www.retrevo.com/support/Toshiba-57H84-TVs-manual/id/311ag813/t/2/
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and sound effects of TV programs and videos that are closed captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the current program, such as weather or stock data (when provided by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2.Press MENU, and then press x or • to display CUSTOM menu.
3. Press y or z to highlight CC, and then press ENTER.
4. Press y or z to highlight CAPTION or TEXT, and then press Enter.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Apr 09, 2010 | Toshiba 57H84 57" Rear Projection...
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
SERVICE MANAUL FOR A 57H84 toshiba
Hi
Click on the following link: Click Here
Please remember to rate this solution as FixYa!
Kind regards
BearWeb
Apr 12, 2009 | Toshiba 57H84 57" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
