Question about Tomtom One XL GPS Receiver
Require value of D5
Can somebody please tell me what type of diode D5 is? It's adjacent to the USB socket on the other side of the pcb.
If anyone has a component list and/or schematic I'd love that too. Please advise & I'll supply email address.
Thanks,
  • 2 more comments
  • Anonymous Sep 25, 2008
    D5 blew here, released the 'magic smoke' at an arbitary time
    slightly worrying if this is a regular occurance, darned thing was a month out of warranty
    i've a feeling that, being where it is, it's a reverse polarity protection diode, shouldn't really have to worry about its value,
    will try shorting it once i find my soldering iron
  • Bubba1965 Sep 27, 2008
    Thanks support551.
    I had a feeling it was for reverse polarity protection. Either that or a 5V Zener. Thanks for the info. Greatly appreciated.
  • gls_1959 Jan 22, 2009
    Does anyone know if the Rectifier Diode D5 on the TomTom XL is the same one used on the TomTom One unit?
    Thanks
  • henrikss Feb 17, 2009
    I have the same problem and I will get a new diode tomorrow.
    BUT which way do I mount the new diode?
    The old one is toast so I can not see any markings.
    Thanks!
TomTom One uses a Linear Technologies chip LTC3455 as a USB/charger power controller. See http://cds.linear.com/docs/Datasheet/3455fc.pdf. This chip is susceptible to high transient voltages that result from resonances created by parasitic inductances and capacitances of the USB/in-car charger cable . Good designs using this chip suggest that a 1 ohm resistance be put in the path of the cable to reduce the Q of the resonance and hence transient voltages. A 6V Zener diode D5 also serves to protect the chip from these transients.
If the Zener diode is blown it is most likely the the LTC3455 chip is gone as well. You can replace the chip which costs £5.00 (located in the shielded portion of the PCB). The recommended Zener Diodes for this chip are either the EDZ5.6B or EDZ6.2B manufactured by ROHM (http://www.rohm.com/products/databook/di/pdf/edz5.6b.pdf or http://www.rohm.com/products/databook/di/pdf/edz6.2b.pdf). These can be used to replace D5. The STMicroeletronics SM2T6V8A can also be used to replace D5 (http://www.st.com/stonline/products/literature/ds/8694/sm2t.pdf). All the Zeners cost a modest £0.22. I hope this is helpful.
Emmanuel Zyambo
Posted on Oct 10, 2009
If its the tomtom one xl.D5 is a surface mount rectifier diode.equivlent to the conventional diode 1n4007
Posted on Sep 26, 2008
  • 20 Answers
I have noticed that the D5 diode has burned out on many a Tomtom one xl. Tomtom knows this, that is why warranty is for a year and why they have no out-of-warranty repair. I sent the info to Consumer Reports.
Posted on Aug 06, 2009
I have electrolux washing machine EWF10741 one resistor on the control board was burned out R57 What is the Value of that resistor?
I have the same fault. I'm in Malaysia. The R57 is the blow out resistor for the "compter section of the board. Mine appears to have been caused by the Transient Voltage suppressor clamping. TRSB1 and possibly the diode (ultra fast rectifier) D5.. Did you find the resistor value?
Sep 05, 2016 | Electrolux Washing Machines
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
Boss RC-3 does not power on, any information about why this unit stop working. Clearly seems to be the power source section on main PCB, if somebody does have an schematic please contact.
Most likely the device has been incorrectly powered. The most easy way to check this is the following:
- unscrew the 4 screws on the RC-3 bottom
- slide the board out from the connectors holes
- gently detach all the connectors and wires coming to the board
- locate the schottky diode (SS14) close to the power input connector
- check if the diode is short
- replace the diode if it is
- if this does not solve the problem probably also the capacitors in the power section are shorted.
Message me for further info
Jan 01, 2013 | Roland Boss RC-3 Loop Station Compact...
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
TomTom One does not power up - burnt component D5 or D9?
Emmanuel Zyambo
Jan 13, 2009 | Tomtom ONE GPS Receiver
Mitsubishi cs40507 blown zener diode
It should be at the back cover, just where the model number is. If you have the TV open, it may also be found inside, maybe on or around the tuner area.
Feb 22, 2008 | Televison & Video
D20 Diode value on Motherboard.
Contact Dell support. Tell them that you were told by a tech (that has repaired many of these problems) that you believe you have a motherboard with leaky capacitors (do not mention the burnt out diode, just tell then it no longer boots). After much interaction with Dell technicians, it turns out that dell has extended the motherboard warranties of most of their PC's including laptops. I know of two people so fat that have had Dell warranty repairs done, even though the system was out of warranty. Once they hear "leaky capacitors" they will advise you that even though your unit is out of warranty, they will replace it. Hope that helps! Best regards
Jan 31, 2007 | Dell Latitude D505 Notebook
Tomtom One XL GPS Receiver Logo
3,123 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
