Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
HI the small flapper door that allows the ice to drop down is just hanging there. I don't see anything broken but do know how to take the front cover off to gain access. the fridge is a whirlpool sxs model wd5002d00
peyton32034
  • 410 Answers
SOURCE: Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Posted on Dec 11, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Posted on Oct 23, 2009
SOURCE: The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
my ice depenser is only making a couple of ice cubes the others are staying iin the ice cube tray
Posted on Dec 23, 2009
womanizer67
  • 12 Answers
SOURCE: My freezer is working, my refer is not. In the
You seem to have defrost problem. Check if the defrost heater is operational if yes change defrost timer...
Posted on Jan 24, 2010
SOURCE: rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Posted on Apr 04, 2010
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
Where does the small tube from bottom of float bowl go
First, where does it come from. It is the overflow for the carb. Comes from a tube inside the carb. Where it goes; basically out the bottom of the bike. It does not connect to anything. just routes down the frame and out the bottom of the bike. It allows any overflow fuel to not get all over your bike.
Aug 16, 2014 | 2003 Harley Davidson XL 1200 C Sportster...
I have an LG model LFX25974ST refrigerator. My issue is the ice flapper that allows the ice to drop will not open.partment and clog up. if i hold the flapper door open manually the ice drops down and
http://c.searspartsdirect.com/lis_png/PLDM/F1107036-00005.png
405A
on diagram Motor,dcPART NUMBER: EAU59551201 $27.41
Back ordered Call Marcone appliance ... Or goto searsparts
but this is the part you need.... To access it take outer door appart
see diagram on searsparts.com
Jan 16, 2014 | LG LFX25960ST Stainless Steel French Door...
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
WATER DRIPPING IN DISPENSER TRAY DUE TO ICE MELTING AT FRONT OF DISPENSER
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
Helo I have a KitchenAid KSBS25FKWHOO which is like this one. My problem is there is a push button for ice cubes or crushed ice and as of now no matter which button i push it gives crushed ice. How can I...
It sounds like your crushed ice flapper might be stuck.
Open the freezer and remove the ice bin by pulling toward you. Dump the ice into a container if you wish to save it.
Turn the bin upside down and look at the opening in the front that the ice drops out. There is a white flapper door that is controlled by a metal rod going all the way to the back of the ice bin. If you move the metal arm up and down from the back you should see the flapper door open and close. Open is for cubed ice and closed causes the cubes to travel through the blades and be crushed.
The most common failure is ice or frost build up around the flapper door that causes it to stick shut and not move to the open or cubed position. You can unthaw by running warm water through it in the sink. Dry completely before returning it to the freezer. Clean out any ice chunks from the chute in the door that might be slowing down ice. That should fix the problem.
Apr 18, 2010 | KitchenAid KSBS25IN Side by Side...
Freezer side has icing problem
check to see if the flap for the ice maker is open and or in need of cleaning, also look at the gaskets on the unit. Put vaseline on them if they feel brittle and it wilkl rejuvinate them.
Feb 01, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice door flapper does not open
It is possible that the solenoid wire connections may have come loose.  You will have to pop off the front cover of the display panel to gain access to the solenoid.  To remove the panel, look below the bottom of the panel to find 2 screwdriver holes.  Slide a screwdriver in one of them and gently pry open the panel.
Aug 11, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice dipsencer door flap
You have a Mechanism delay come out. it holds the flaper open and close it slowly. is the end with the arm on it broken you will have to disassemble the dispenser front to get the new one back in... let me know Thanks
Aug 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
