Question about Optoma MovieTime DV10 Multimedia Projector
Abrupt shut off
This is a very new unit, used on a couple times. when I power up I get a quick flash from both the temp and lamp as well as the blue power button. the fan starts and in a moment the lamp comes on.
After about 4 mins the whole projector shuts down. The lamp, and the fan.
I'm sure it has to do with overheating and that this is an internal safety feature but what is causing this. This is a new, pristine device.
thanks
  • 3 more comments
  • LINGI Jun 17, 2008
    when i switch on the power the blue light flashes and go off
  • hostagelures Oct 26, 2008
    Our Optoma, a different model, did the same thing after we had it for about 8 mos. We sent it to CA to the factory for their repair, and they returned it after about a month. We have had it back a month and a half and it has done it again. What gives with the safety switch?? We are tired of waiting for it to come back from the factory. Is there a place where we can get replacement parts?
  • awine1 Nov 23, 2008
    my dv10 will play for about 10 min and then shuts off, lamp light blinking.
    should i try a new lamp or look for a better projector?
  • brookshou446 Nov 25, 2008
    After playing for 5 - 8 minutes, it totally powers down and will NOT power back up for another 20 minutes. During this time, the power button which is normally backlit in blue light and flashing is totally dim as if it were unplugged. After 20 minutes, the power button starts flashing and is backlit in blue as normal. It will power up but the problem will reoccur.
  • Tarly Chan Dec 08, 2008
    I had the same problem, I changed the kettle lead i was using and it now works perfectly. I now use a 3 amp kettle plug.
  • 167 Answers
Faulty bulb?
Posted on Jul 02, 2008
Powers on and quickly shut off and red lamp indicator flashes
check the lamp which busted then the fan which not working.
Apr 19, 2013 | Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
Apr 08, 2010 | Optoma MovieTime DV10 Multimedia Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Problem with tv
Pretty typical for lamp life. Buy a new bulb (not the whole lamp assy) from us (sedonix.com) or one of the many bulb sources on the net, install it yourself and save a lot.
Dec 31, 2007 | Televison & Video
Optoma MovieTime DV10 Multimedia Projector Logo
231 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
