Were do I buy a T CON board for my JVC TV. - Televison & Video
  • 476 Answers
There are several e-stores that can help you, you will need a model number for your JVC TV. Try Encompass.com and another e-store is hbfelectronics.com// Good luck
Posted on Nov 06, 2010
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 09, 2015 | JVC Emerald EM37T 37" 720p LED-LCD TV -...
My jvc flat screen tv has no picture but with sound.
If this is LCD you possibly have a faulty inverter board or t-con board
Inverter board--if you have image/picture when you used flash light on screen that is the prblem..
if not t-con
Oct 13, 2012 | JVC Televison & Video
Yellow lines on jvc lcd tv
tried to re seat first the cable at the t-con board that transfer signal on the screen panel display which may have loose contact on the connector.
Aug 12, 2012 | JVC 42 in. LCD TV
The colors of the tv are fine except for the blue, things that should be blue are green
The board that called the T-Con board it is could be dead.This T-Con board control the out put tv signal to the tv LCD screen panel.This T-Con board sit at the bottom in the middle bottom of the tv LCD screen panel. Take the connection out of the T-Con board .Tries clean the connection of the board with some rubbing alcohol,might fixed the problems,if not.Tries websites like Shopjimmy.com,EBay.com to buy a refurbish T-Con board for the replacement.
Jun 01, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
How to replace JVC lt-42x688 t-con board.
Assuming this is the same as my jvc 42x788 the small t-con board is near the top of the tv. It's behind the main panel that the other boards are mounted to. You don't have to take that main panel completely off, just take enough screws out to pull it out far enough to reach the t-con board. Also watch for any wires that need to be unplugged to get more room pulling the top of the panel out.
Apr 08, 2012 | JVC LT-42X688 42 in. LCD HDTV
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
INTERMITENT , VERTICAL BARS OF RED AND GREEN BUT THE PICTURE IS GOOD BEHIND BARS
This tv problems,it the causes of the tv board that call the T-CON board,it is dying.This T-CON board job are to decodes and filters all pixels dots pictures before it goes into the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Jun 27, 2011 | Samsung LN46A500 46 in. TV
Tv have white screen no picture
Tuner board is dead.That the board,where the brocasting signal cable plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 10, 2010 | JVC LT-40X776 40 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
