Question about Sony KP-57WS500 57" Rear Projection Television
My sony kp572s500 tv has no picture. the screen has a red hue than shuts down. what could cause this?
    Top Expert:
  • Sony Master
  • 14,553 Answers
This model is prone to bad picture tubes (there are three) but I can tell you way to attempt to correct for this, no parts are involved and only ten minutes of time needed.
Can I help?
SD TECH
Posted on Nov 06, 2010
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture is distorted
Is your TV near anything magnetic ? This causes picture issues. If the thing is a tube TV then you can fix this fault with a magnet. Call 0845 20 20 118 for help
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Red screen on my sony kp-53s25,
That model is famous for bad green CRTs which can cause the screen to take on a red hue when the green cuts out that can also cause the set to get blurry also. Let me know if you need more assistance.
Jun 12, 2008 | Sony KP-53S65 53" Rear Projection...
Sony turns on and off again
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture qualiry
Try adjusting the setting of "hue" control of TV.It might be the wrong setting & the ratio of red hue could be more than the required one.
Apr 08, 2008 | Sony KP-53HS10 TV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony bravia lcd tv
Are you connected to a cable box or satalite rcvr using compoment outputs (y,pr,pb)? It is posible that the red cable has come loose and picture has no red,causing a mostly blue picture.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
