Question about ViewSonic Computers & Internet
My ViewSonic VX240W goes blank after 1-2 seconds each time I turn it on. I tried the monitor on another computer, same results. The picture (while up for 1-2 seconds) looks fine, then blank screen.
SOURCE: Monitor goes blank less than a second after turning on.
If you see picture on LCD when shining to the panel with flashlight as someone worte in first solution, the problem is in the inverter board as has been written. You may try to change electrolytic capacitors on the inverter board, there usualy are only few of them and they are cheap. But you need basic skill with soldering. If doesn't help you have to change the inverter board.
Posted on Jan 30, 2007
SOURCE: vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
Posted on Jul 13, 2007
SOURCE: Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
Posted on May 06, 2008
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
var-pun
  • 331 Answers
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Posted on Sep 06, 2008
I have a view sonic 1912wb a blank screen come on for 1 second then goes of. Can this be repaired?
The problem of this unit is bad or bloated electrolytic capacitors like this image:
bc3eb3e.jpg that is common to viewsonic monitor.
Sep 29, 2010 | ViewSonic VA1912wb Monitor
My viewsonic vx924(vs10162) start very good when i turn on my pc then after 2 or 3 seconds goes white but i turn it off and on again and it works just fine i try it with other pc and does the same what can...
The picture board on your monitor is bad, since the power led or button is on and all connection are correct and goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 04, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
My monitor will display the picture for approx 1-2 seconds, then the word "analog" is seen and immediately the picture disappears. Bottom line: the picture won't stay on.
I assume that you have already try this monitor with new VGA cable and with another PC but still get the same result, just want to narrow down the problem before opening it up.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC nad other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 02, 2010 | ViewSonic VX910 19" LCD Monitor
VP191B VIEWSONIC MONITOR POWER ON AND PICTURE SHOWS FOR HALF A SECOND THEN GOES BLANK, POWER OFF AND POWER ON PICTURE FOR HALF A SECOND AND GOES BLANK
More likely to have problem in either the backlight light inverter board or bad lamps due to poor solder connections, see http://s807.photobucket.com/home/budm/allalbums
You will need test lamp to narrow down the problem.
Feb 05, 2010 | Computers & Internet
Viewsonic vg2021m monitor goes blank.
the probelm u are having mostlickly the backlight is out on your monitrer. thy CAN be replaced but with all the time it takes and money to do them i sugjest just getting a new moniter.
Dec 31, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Viewsonic VA721 - Screen goes blank for second or two and returns
Sounds like its going to sllep too soon make sure you do not have it set in your video card settings. also try it on a diffrent computer. if that does not shore it up replace the acpi board
Jun 11, 2009 | ViewSonic VA721 17" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor screen turns off almost immediately
Do you connect all monitor wires on ... Do you got with screen or computer some MSI thing... the monitor blue wire must connect that thing then that MSI or whatever must connect to computer
Mar 08, 2009 | ViewSonic Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
