Question about Honda Water Pump Honda Engine
What type oil do use when I change the oil on my honda 5.5hp pump
    Problem Solver:
  • 8 Answers
Straight 30 weight oil
Posted on Nov 06, 2010
Oil light comes erratically on 92 accord
my guess is one of three things:
1. clogged inlet or worn out oil pump gears: change oil pump
2. Engine is tired and has leaky loose bearings and journals, hemorrhaging oil out all internally bleeding places. Engine flush unclogged the varnish that was holding oil pressure up. Rebuild engine or change when current engine blows.
3. Bad oil pressure sensor causing strange readings. Diagnose actual oil pressure and change sensor if needed.
These vintage honda engines are everywhere for cheap at junkyards. i wouldnt pay more than 350 for one.
Feb 17, 2015 | 1992 Honda Accord
What type of oil for XL honda motor with Cat pump
the motor 30wt oil or 10- 30wt, the pump takes pump oil or 30wt
non-detergent, so the answer is no they don't take the same
Sep 14, 2014 | Honda Garden
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
What type of oil do I use for a 1993 Honda XR 250? How much oil do I put in it?
I use semi-synthetic 20W50 and change the oil every 3500-4000 km.
I do the filter at the same time.
Oct 09, 2012 | 1993 Honda XR 250 R
Honda 2005. is not pump engine oil very well solution
Your having oil pump issue you should consider seeing a certified mechanic this is a internal engine problem .A car hoist is required to do this type of job and is time consuming.
Dec 27, 2010 | 1995 Honda Accord
My Troy Bilt power washer (using Honda GCV160 engine) has no pressure coming from the pump. I checked the water flow, everything seems fine. I believe the pump needs oil added, however, I can't seem to...
I had a similar problem. Turns out I had left the hose disconnected and some sort of wasp built a paper type nest inside the washer tube that the hose connects to. I had to take the pump off and take apart and then cleaned it out with a screw driver. Not too easy to do but finally got it clean. Same thing happened with the hose.
So, if you haven't used it for awhile, check that there is no blockage in the hose or pump tubes. You might be able to blow it out with an air compressor.
Nov 21, 2010 | Honda Black Max 2600 PSI Pressure Washer
For a honda 125 cbr how often do I change the oil and what type does it need?
oil change: every 1000km
oil type: silkolene comp 4 10w/30
quanity oil: 1000mls
Nov 03, 2009 | 2005 Honda CBR 125 R
Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Jul 27, 2009 | Garden
Honda Water Pump Honda Engine Logo
90 people viewed this question
Top Honda Tools & Hardware - Others Experts
gbob59
John Loiselle
Level 1 Expert
Bill Boyd
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
