Question about Mitsubishi WS-65807 65" Rear Projection Television
Words on screen are 3 different colors blue red green, no picture just black screen when changing input and input channel words showing in diff colors
Am using the t.v with a digital decoder... It was not sensing the remote then I tried to change it from channels to AV but it was just on the blue screen until when I switched it off from the wall then on again and from then it just has the red light and silent black screen it is like it's on standb ymode
Posted on Sep 13, 2016
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
YOU may have two problems, 3 d picture or letters suggests convergence problem, Tell me more, all inputs have no function?
The more you tell me the better I can help.
I am expert with these sets and know them well.
SD TECH
Posted on Nov 06, 2010
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Green and blue faded
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
Apr 15, 2012 | Sony KP-65WV700 65" Rear Projection HDTV
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Color problem with Sony Grand WEGA 42WE655
Well, there probably isn't any relation between the two problems occuring exept for the timing. Magnetism won't affect a rear projection LCD.
I would say that your description is a bit odd, though. Usually on this model, there is a blue blob that shows up, eventually turning into a blue haze, and a star pattern of stuck pixels. It almost sounds like you have a bad set of component cables. On the SXRD's, they usually turn green.
Does it do it on all inputs (including the channels)? If it does, then it is the optical block. If it does not, then I would suspect that it is cable-related. If it is the optical block, then there is no way that any input can be different from the others (except for digital/analog differences, but those are usually obvious with patterns vertically on the screen).
If it does not look the same on all inputs or channels, change out whatever cables you are using. A loss of the red or blue cable in a component can give the symptoms you describe.
I hope this helps you...
Jan 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
