Question about Furuno NavNet vx2 1920C GPS Receiver
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
    Scholar:
  • 111 Answers
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Posted on Jan 07, 2011
How do I repair a cracked Furuno Radome? The top white part is cracked from a tree branch
No, a quarter sized blank area around boat on lowest 1/8 mile range is normal. The dome cover is available for just over $100., so why risk a leak?
John 847-746-0100
May 01, 2014 | Furuno 2.2kw 18" Radome
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
My radar displays all contacts reverse. How do I get the display reversed? model #1731
I agree with Nico-Fixus, the heading alignment is one of the things to be checked. Unless this is a new installation it is unlikely that the Radome (antenna) got removed and reinstalled facing the wrong way. So antenna orientation would not be a concern.
I have seen units that for some reason the wrong Radome was selected in the configuration of the Navnet display.
Read the model number on the Antenna, then check that correct antenna type in loaded in your display.
Oct 22, 2009 | Furuno Navnet 1732 GPS Receiver
My furuno navnet vx2 periodically freezes during operation and must be restarted. Any suggestions?
Reinstall the operating software. The unit should probably go to Furuno.
Try operating it with only a GPS connected (no radar, no network). If this resolves it, it is almost certainly software. It could be low voltage or failing mother board.
Jul 15, 2009 | Furuno NavNet vx2 1920C GPS Receiver
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Apr 06, 2009 | Furuno 2.2kw 18" Radome
Adapt 997c si gps to navnet furuno sounder
no can do you must have a Furuno GPS or a GPS with NMEA 0183 output. you could get that from the Hummingbird display but not straight from the antenna
Feb 27, 2009 | Furuno NavNet vx2 1920C GPS Receiver
Navnet 500
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Apr 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno NavNet  vx2 1920C GPS Receiver Logo
313 people viewed this question
Top Furuno GPS Experts
Ron Dufek
Ron Dufek
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
