Question about Seagate (ST3160827AS) 160 GB Hard Drive
Seagate 160 gb capacity problem
Dear sir i have seagate 160gb sata hard disk. in bios it shows 160 gb but in actual it gives only 152gb. i have tried to dm it but no dm matches it. then i tried ontrack to it. it shows 160 gb. but after it when i tried install windows xp it shows only 152 gb. how can i make it full 160 gb. pls solve my problem. & mail me
  • Anonymous Nov 14, 2008
  • 13,433 Answers
The harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
Seagate 160 gb capacity problem - 894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Posted on Jun 15, 2008
Dear sir i have seagate ST3160215AS 160gb sata hard disk. in bios it shows 160 gb but in actual it gives only 149gb. i have tried to dm it but no dm matches it. then i tried ontrack to it. it shows 160 gb....
the hard drive might be damaged bad sectors
the operating sytem will take/use a certain ammount of space onyour hard drive
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
hope this helps you
Oct 23, 2011 | Computers & Internet
The hard disk not detect in my compter
Hi Good day!! try to re-plug the sata cable and power adaptor of your hard disk and see if it is detected if not try to replace the sata cable. please reply if you have a question i will help you more.
Thank you for using FixYa
Nov 09, 2010 | Seagate 25PK 160GB ST3160215AS SATA 7200...
I bought gb seagate Hard disk i am not able to formate from DM or fdisk utility, & from xp i lost 24 gb space then what can i do.
have you tried
click start run type cmd then type chkdsk/r/f which will automatically fix any corrupt files and scan for bad sectors and recover on your hard drive then defragment your hard drive
hope this helps
Sep 28, 2010 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Seagate satat error
the firmware is damaged,sir,nothing can should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk failure... unable to start
You need to get a new Hard disk. There is no way to get info off the Hard disk that won't turn in because theres probley a short a an element that failed and burned out. Hope this helped. =)
Feb 25, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard Disk Drive Not Detected
Does your hard drive get detected in the BIOS? If yes then you can recover data by plugging that hard drive as secondary and running a recovery application like Recover My Files.
Dec 23, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Seagate (ST3160827AS) 160 GB Hard Drive Logo
199 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
