Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
It says i have a static ip biut it has no internet connection and then tells me to enter it manually
  • 91 Answers
DEAR SIR,
LOOK FOR DHCP IN WAN & DISABLE IT , THEN YOU CAN PUT YOUR STATIC IP & DNS ETC
REGARDS
RAJ
NPCONLINE
Posted on Nov 06, 2010
My dlink dir615 is working fine when I was with comcast cable, now i need to reconfigurate with my att. modem wchich require PPPoE connection, how can I do this?
  1. Access your router's admin page by pointing your web browser to http://192.168.0.1
  2. By default, username = admin and password = blank, no password.
  3. Go to the Setup Tab.
  4. Click on the Manual Internet Setup options
  5. Then, under Internet Connection Type, you choose PPPoE from the list.
  6. Enter your user name and password that your new ISP provided you.
  7. You also need to answer if you have a static IP or Dynamic IP. If you are given a static IP by your ISP, then you should also put it there.
  8. Then you're good to go.
Just give it a try and post me feedback if there are.
Aug 14, 2010 | D-Link DIR-615 Wireless Router
Will not acquire an ip address on a working
do you have static IP ? if so you would need to enter them by hand in to the internet connection in XP
Jul 23, 2010 | Acer Aspire 3050-1733 Notebook
I am trying to install the WRT160 N router, but can't install it due to having a Static IP. What should I do? The set up CD is giving the message that the the ethernet cord isn't plugged in. All I am doing...
Do not run the set up disc do it manually.
.You said that you have a static IP.
Is the static IP for the internet service provider or it is on the computer.
If you have set up the static IP on the computer then you will need to remove the static IP address from the computer and set it to obtain IP automatically.
If you have a static IP given by the ISP then you can use it to set up on the router.
Check the Ip address of the computer when connected to the router.
I believe the default gateway will be 192.168.1.1.
open the set up page of the router. default password of the router will be admin. Once you open the set up page of the rotuer, you will find the option Internet connection type. set it to STATIC IP address.
then you will get the option to enter the static IP address given by ISP.
Enter the information and Click save settings at the bottom and you will
be able to go online.
Click Here for More Info
Oct 06, 2009 | Linksys WRT160N Wireless Router
I have sony VAIO VGN . I am not able to connect to wireless internet. Only local connection is established but does not connect to Internet. I have tried different locations and IPs.
It is because the DNS address may be set to static. make sure you insert the DNS ip address by right clicking on your network icon and then select status, then properties. select internet protocol then enter the static DNS address. you can obtain it from a machine connected to the network with internet access by typing ipconfig/all in a command prompt. hope this solve your problem.
to enter command prompt click on start then select run, and type cmd and press enter
Mar 14, 2009 | Computers & Internet
Laptop ip stuck on same nr
You can release and renew the IP.
Go to command prompt and enter ipconfig /release, press enter
and then type ipconfig /renew, press enter
see if it works.
(note:there is a space between ipconfig and the /)
Jan 27, 2009 | Sun 501-4366 X1034A PCI Quad FastEthernet...
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type 192.168.1.1
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
e.g. 192.168.1.2
7.) Click on DHCP AND ENABLE THE DHCP SERVER
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g 192.168.0.1
13.) as your primary dns enter your modem ip e,g 192.168.0.1
14 save changes and exit
YOU CAN HAVE THE ROUTER AUTOMATICALLY ASSIGN AN IP ADDRESS TO EACH SYSTEM OR YOU CAN SET IT AUTOMATICALLY
FOR AUTOMATIC ASSIGN JUST CONNECT THE CABKLE
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g 192.168.1.10
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g 192.168.1.1
Enter the Prefered Dns as also your Modem ip 192.268.1.1
cheers
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
