Question about GE Dryers
GE Dryer Model DPGT750EC2WW - Problem is that it takes a very long time to dry. I cleaned out the vents and didn't help. The lint filer only picks up lint only in the outer edges.
  • GE Master
  • 8,220 Answers
Take your vent pipe off and check for a blockage or an air restriction. If everything is ok I would check your circuit breaker. It may be going bad.
Posted on Nov 06, 2010
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
Its not drying the clothes and is taking longer to dry. is there a way to reset?
Dryer Repair. In most cases the problem lies in the vent. Your vent may have partially blocked with lint. The first step is to have vent cleaned out by a vent cleaning company or else buy the "whirlybird" drill attachment and do it yourself. Of course, this is assuming you are getting heat inside the drum. Hope this helps,
Sep 29, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
My ge Profile dryer is 5 years old and for about a year the drying process became slower and slower as the heat within became cooler and cooler! Im thinking thats the heating element. My question is how do...
This is dued to lint build up in the dryers venting tubes. If you completely tear the vents off and clean them inside thoroughly it will run like ne again. It will be better to replace accordian stle tubes than to clean them if that is what you have on yours
A moister sensor detects the build up and keeps the heat in check
Jul 01, 2010 | Dryers
Getting Hot, but not drying the clothes
there has got to be some restriction in the vent system. Take the vent pipe completely off and look in the tube coming directly out of the dryer. Also make sure the drum is turning good speed.
Jun 07, 2009 | Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
